Series Names
    • 22943
    Series Names
    Can any of you dedicated Konica Minota techs list the model numbers that you can match up with Series Names? I didn't get much formal Konica Minolta training. =^..^=
  • EarthKmTech
    Step aside, noob
    • May 2009
    • 2139
    Re: Series Names
    I work for KM and about the only time I've ever needed to answer that question is in an assessment.
    In the real world I'm still yet to experience a single example of when that knowledge was remotely necessary and I've been doing this for 15 years.
    • fixthecopier
      ALIEN OVERLORD
      • 4714
      Re: Series Names
      It's early Sunday morning and I went to the company Halloween party last night, so I am not sure I understand the Question. Do you mean list all of the EP, and Di's and bizhubs? If that is the case, I know most of them without looking.
      • JSC
        Gimp
        • Dec 2006
        • 618
        Re: Series Names
        Hi Blackcat4866
        do you mean for instance the Zeus range= C224, C284, C364
        Minerva range= C654, C754
        The gene pool could use a little chlorine.
          • 22943
          Re: Series Names
          For example:
          Copystar CS-3050, CS-4050, CS-5050, CS-420i, CS-520i
          Kyocera Mita KM-3050, KM-4050, KM-5050, KM-420i, KM-520i
          ... all are part of the Falcon III family. That is to say they all use the same print engine, and basically the same consumables. This is useful information when you're comparing consumables, yields, simulations, and fixes that apply equally across the family.
          So I was trained on the bizhub C220, C280, C360. There may be printers using this same engine. Is there a series name? =^..^=
            • 22943
            Re: Series Names
            Originally posted by JSC
            Hi Blackcat4866
            Yes, exactly. More? =^..^=
            • fixthecopier
              ALIEN OVERLORD
              • 4714
              Re: Series Names
              Sorry it took me so long, I was gone all day. I don't know if this is what you are looking for , but here goes.
              The Di 250/350 are the same except for page speed. They made the iu's different, but taking pliers and snapping off the tap under it that keeps you from swapping them, makes them interchangeable. Toner is the same, the bottles are different because of yields.
              The 520/620 machines are the same except for boards.
              The Di 200/ 251/ 351 are the same class. IU's can be swapped by snapping off the tap on bottom.
              The 7272 and 7255 and 7210 are the predecessors of the 650 with the 7210 being closer to the BZ 600.
              As far as mechanical parts there is a lot you can swap between all of those big boxes. The 650 did not have photocells under the transfer to detect the cleaning motion, so the transfers are different by way of the 600 having a flag under the cleaner on transfer.
              The 2010, 2510 and 3510 are same class of box, mostly interchangeable except the boards are different . With the exception of boards, these are good parts machines for the Bizhub 200/250/350 machines.
              I don't know a lot on color, hope this helps.
              Also a lot of the larger older HP color engines are Konica.
              • emujo
                • Jun 2009
                • 3009
                Re: Series Names
                Sorry for the "cut and paste" quality, but here they are. Emujo
                • JustManuals
                  • Jan 2006
                  • 9838
                  Re: Series Names
                  Try this site:
                  Katun Corporation - World Wide Equivalency Lists
                  HTH.
                  Paul
                  • Hansoon
                    • Sep 2007
                    • 3350
                    Re: Series Names
                    Im baffled, going with Minolta since the EG machines and EP-1 I never heard of it. Thanks
                    Hans
                    “ Sent from my Intel 80286 using MS-DOS 2.0 “
                    https://www.copytechnet.com/images/smilies/biggrin.png
                    • habik
                      • 2013
                      Re: Series Names
                      Thanks Emujo and Paul for this brilliant info! Appreciate it.
                      Firmwares HERE
                      • habik
                        • 2013
                        Re: Series Names
                        Hans
                        I am sure you did when downloading firmware etc you have it there either on the printed bulletin or within the FW name... I was always wondering what it meant, and now I have clear vision Mosel in my case
                        Firmwares HERE
                        • JustManuals
                          • Jan 2006
                          • 9838
                          Re: Series Names
                          I also have a file on Ricoh machine names to machine codes, if you want it, just email me and I'll send it along.
                          Paul
                            • 22943
                            Re: Series Names
                            Thanks JSC, emujo, fix, Paul. You're a big help. Thanks. =^..^=
                            • fixthecopier
                              ALIEN OVERLORD
                              • 4714
                              Re: Series Names
                              I also have not seen such list, so my question is, How do these list benefit you in troubleshooting? I understand for cross referencing supplies and parts, but I have other ways to do this, what info will these list give that I should need?
