C280 With PC 207
  • big jase
    • Jul 2008
    • 136
    C280 With PC 207
    Im getting J20-02 jams from tray3 , doesnt matter which size paper is in tray it feeds around 10-15 then jams , i have replaced the spring clutch, reaplaced all feed tyres , i have also replaced the registration clutch ,tray 2 feed clutch and the drive /feed moters on tray 3
    Please help driving me crazy!
    If at First you don't succeed remove all evidence of ever trying!
    • 22946
    Re: C280 With PC 207
    Have you cleaned with alcohol and oiled the one-way bearings. Every time I have the feed unit out, I make sure to do so, as a preventative. It's a very common failure, and does not require new parts. =^..^=
    • EarthKmTech
      Step aside, noob
      • May 2009
      • 2139
      replaced all the tires hey...
      when you replaced the separation roller, did you reuse the existing torque limiter or replace it ?
      I've had this very head scratching issue caused by a failed sep roller torque limiter before.
      considering it and the 1 way bearings are half the price of the rollers $4 versus $8- just throw them away and replace them at the time of replacing the rollers, but its your decision at the end of the day what you do, this is what I do and it works for me.
      • big jase
        • Jul 2008
        • 136
        Thanks blackcat will check the one way gears ,
        Earthtech. I replaced the full step roller assembly, as had same issue you said before
