I Have GR1750 with error code E 03. Any ideas on what to do? Any help is greatly appreciated..
riso GR1750 error code E 03
Another thing to look for if the drum will not return to home position is that the clamp plate delayed going to master removal position and is caught in the disposal hooks / disposal ass'y. In this case you have to go in through the top of the unit (master making area - right side of unit) and rotate the drum back towards the paper receiving tray, until the center of the clamp assembly is at the 12 o'clock position.
Good luck!Last edited by techathens; 04-06-2008, 03:33 PM.Salesout Pro
SalesoutPro@gmail.com
The clamp on the rear of the drum has a magnet that tells which position (open or closed) the clamp is in. Sometimes the screw backs out and the magnet falls out or gets bent so it doesn't give the proper reading. The magnet should be opposite the clamp and should be keyed to only go on one way. I've also seen the plate that retains the clamp plate become broken, usually by opening or closing the drum out of the home position.the savin2535 is displaying well bet the hiter lamp is not shining and the lamp had been tested o.k.please kindly help.Samir: No, not again. I... why does it say paper jam when there is no paper jam? I swear to God, one of these days, I just kick this piece of shit out the window.
Michael Bolton: You and me both, man. That thing is lucky I'm not armed.Comment
Also - if you are having Angular Magnet issues a E14 (T14 on some 11x17 / A3 units) Clamp Error 2 will sometimes be displayed. This is a rare code, but in my experience pops up when there is Angular Magnet issues and the machines "loses" the clamp unit.
And - you will receive these clamp errors if there is a malfunction in the Clamp Solenoid Assembly. The main problem I have found on these is where the Clamp Solenoid attaches to Clamp Solenoid Base Plate can form a hairline stress fracture due to the amount of force exerted every time it is activated. On the newer Clamp Solenoid Assemblies (released towards the end of the series (@1998 - 2000) the screws holding Solenoid can be loosened and the position adjusted. You may also want to disassemble the solenoid and clean.Last edited by techathens; 04-21-2008, 03:29 PM.Salesout Pro
