konica minolta bizhub 200 lines
  • brent
    • Nov 2008
    • 1208
    copy to follow. it has lines that are not in feed direction. this is an 8 1/2 by 11 copy in the portrait position lnes are straight up and down and not in feed direction. am I looking at a bad dv unit? or drum unit? thoughts?
    thanks
    brentbadcopy10.pdf
  • mo0651
    • 1054
    Re: konica minolta bizhub 200 lines
    yep
      • 22946
      Are the lines crisp on the edges or blended?
      Crisp lines might be laser. Fussy or blended edges might be developing, or drum ground. =^..^=
      Edit: Hey! You included a sample. Definitely developing. =^..^=
      • Hansoon
        • Sep 2007
        • 3350
        Looks like the bias/charge is being shorted out. For sure the drum is scored to the bare aluminium core.
        Hans
        “ Sent from my Intel 80286 using MS-DOS 2.0
        https://www.copytechnet.com/images/smilies/biggrin.png
        • RRodgers
          • Jun 2009
          • 1947
          I'd say drum as well.
          • brent
            • Nov 2008
            • 1208
            Yes the drum is scratched. Just thought about it
            weird I have never seen this before
            I will know more tomorrow. Thanks giys
            Brent
              • 14418
              When you replace the drum and dev be sure to replace the transfer roller as well. It is what causes the wear on the drum. I have been using the transfer roller from the BH423 series. They have a wider spacer on them and they don't cause the wear as quickly.
              Hope this helps
              Darren
              • brent
                • Nov 2008
                • 1208
                Hope this helps
                Darren
                Thank you Darren. It's on the schedule to do that
