C360 with Account Tracking On and Mac Users
  • copierwhisper
    • Mar 2013
    • 78
    Hello!
    I have a customer with a Konica Minolta C360 with account tracking turned on and all the PC's work fine, but the users running Mac cannot find where or how to enter their account tracking code from their computer. Any ideas? I have some of them running Maverick and Yosmite (OS 10.9 and OS 10.10).
    • 22943
    Re: C360 with Account Tracking On and Mac Users
    I did this on a Toshiba setup the other day. It shouldn't be any different from the Mac side:
    To set up Dept Code in Mac driver: Open any text document > Print > Show Details > "Safari" or "Layout" drop down to Print Mode > "Department Codes-Disable" drop down to Department Code-Enabled > enter Dept Code > "Default Settings" drop down to Save Current settings as Default > Print.
    • wseyller
      • Sep 2012
      • 1129
      On km device after choosing show details I think the drop down option is "Output Method". You should then find account track and authentication settings there. Just make sure you are using the correct driver for the model in use or it will never work.
      • darry1322
        • Oct 2010
        • 817
        The key point is you have to have a document pulled up to print before you can find the settings menu for account codes.
        • copierwhisper
          • Mar 2013
          • 78
          Thank you for the input! I'm heading the customer this afternoon to try out the settings! My last question for now is, will the settings hold or does the user have to do this process every time they print? Is there a way to enter their code "permanently"?
          • emujo
            • Jun 2009
            • 3009
            You will see the "save" checkbox when you enter the id info. Be advised, not every MAC app supports the account code/user authentication entry. If it's there on some but not on the others, it's not a driver issue. Emujo
              • 22943
              Does this answer your question? =^..^=
              • copierwhisper
                • Mar 2013
                • 78
                Thank you!!!!
