View Full Version : C353, Error: Service Call occurred. 45-52
jayg30
01-09-2015, 03:18 PM
A KM C353 is sending emails with the following.
Doesn't seem to be happening in any pattern.
Occurred Time :MM/DD/YYYY HH:MM:SS
Installed Place:[location]
IP Address :xxx.xxx.xxx.xxx
Also...
Error: Service Call occurred. 25-58
Any idea what this could pertain to? Machine seems to be functioning fine.
CompyTech
01-09-2015, 03:32 PM
4552 is a PH unit failure, more specifically LASER M FAILURE. You'll need a new printhead, these units are prone to failure(design defect). The other code is a high TCR on K IU(imaging Unit). Take out the K IU and toner first, and give them a good shaking. But be prepared to replace the K IU. Also the laser unit is not easy to get to if you're a green tech or end user. Very expensive and time consuming.
jayg30
01-09-2015, 03:53 PM
Thanks. I have it under a service contract but have had issues with getting "correct" diagnosis from them in the past. Your info will help me in dealing with them. I gave the units a shake but will call the tech.
allan
01-09-2015, 04:01 PM
Be careful one dealer only tried to upgrade the machine and quoted them R84 000 i fix it for R 2500 and made money. Is the machine on lease? C200 Y laser.
