intermittently flips rear corner over to top running 11" lead edge. swapped fuser and transfer roller/assembly. skews image. tray 2 and LCC. Forget to try 1 was 8.5x11R and OK. TIA
C360 flips corner skews image
Re: C360 flips corner skews image
CAUSE: The registration rollers have a paper guide which can sometimes be a bit tight so that the sheet catches and becomes folded.
SOLUTION: Ensure that the lift board of the PC-408 and the trays are correctly adjusted so that the stack is parallel with the bucket. If the problem persists, please use a bizhub C554 Cushion (p/n A161164902) to enlarge the space. -
That was my suggestion. =^..^=If you'd like a serious answer to your request:
blackcat: Master Of The Obvious =^..^=Comment
