fs-534 j72-17
  • Issac-brock
    • Jan 2015
    • 61
    fs-534 j72-17
    I am having issues with a few different bizhub models connected to fs-534 finishers.
    The jam code is J72-17, paper is cutting the plastic paddles in the staple/ejector section. I have replaced the paddles on a finisher connected to a BH C554 with several hundred thousand prints but today ran into a c754e with just 69k on it. This is a very recent install but the guides are already cut. I see no adjustments for centering the finisher and only 1 adjustment for the paddle distance which when adjusted makes it worse.
    I adjusted tray 3 and 4 to try and centre them according to the marks on the trays. Couldn't make it jam on both Machines but the evidence is in the blue bin and jam codes.
    Anyone dealt with this?
    Thanks,
    Colin
    • 22937
    Re: fs-534 j72-17
    I've seen it as low as 60K. My theory is that the paper positioning in the tray affects which side (front or back), will have the paper cuts. Logically you should be able to center the paper in the tray to minimize the paper cuts. The next time I see one, I'll try nudging the paper in the busiest tray away from the paper cuts. =^..^=
    • Issac-brock
      • Jan 2015
      • 61
      Re: fs-534 j72-17
      I agree, I've tried to adjust the tray 3 and 4 (lct trays, built in) as centre as possible as these seem to be the primary source of the issue so far. Sad there seems to be no documentation on the centering procedure unless I have missed it,
        • 22937
        Re: fs-534 j72-17
        I looked, and didn't see a centering procedure for the stapling tray regulator plates. If you find such a procedure I would be interested in hearing about it.
        As a temporary fix I have had success with filing smooth the regulator plates where the paper cuts occur, and it seems to take longer to re-occur. It's not the most pleasant job to get to them, maybe 75 minutes beginning to end.
        For those who haven't seen this, here are a few pix:
        • Issac-brock
          • Jan 2015
          • 61
          Re: fs-534 j72-17
          I found a bulletin that mentions j72-16 and j72-18 but had a mod that fits my issue. I add the mylars as my machine started to jam again on large runs. I took out both guide assemblies and they were both cut pretty good. Lucky I had a strip of mylar the exact width described. The part # of the mylar was A00J561000.
          bulletin # TAUS1400198EN
          Highlights of bulletin
          paper guide mode from TAUS1400198EN.pdf
          Here is a shot of my modded machine. Also turned off the Offset Feature in Printing Defaults.
            • 22937
            Re: fs-534 j72-17
            Thanks for sharing. Let me know how it goes. =^..^=
            • Issac-brock
              • Jan 2015
              • 61
              Re: fs-534 j72-17
              First day of feedback, no jams. Users reported no issue, they run a large batch evey morning with about 2500 pages per day.
              • antone
                • Oct 2014
                • 344
                Re: fs-534 j72-17
                Is their a good way to installation of these guide's! Not sure on how to install this mode?
                • Issac-brock
                  • Jan 2015
                  • 61
                  Re: fs-534 j72-17
                  You need to remove the assemblies, takes about an hour to an hour and a half to complete.
                  • antone
                    • Oct 2014
                    • 344
                    Re: fs-534 j72-17
                    Thanks you!
                    • Ingersoll
                      • Nov 2008
                      • 74
                      Re: fs-534 j72-17
                      Do you have the instructions to remove those?
                        • 22937
                        Re: fs-534 j72-17
                        Like this?:
                        • Ingersoll
                          • Nov 2008
                          • 74
                          Re: fs-534 j72-17
                          Like this?:
                          Many Thanks, didn't have the manual.
