bizhub C454 with FS-534 jamming C3205 horizontal transport section didn't start
  • Laserbeam
    • Aug 2011
    • 152
    [Jamming] bizhub C454 with FS-534 jamming C3205 horizontal transport section didn't start
    Hello to all,
    today I had a strange problem with a bizhub C454 and finisher FS-534. The paper leaves the paper exit section, but the horizontal transport section (Finisher FS-534) didn't start. After rebooting the machine, usually some copies can be made, but then the old problem is back. By single copies, the machine doesn't display a jam message on the display, only by multiple copies when the backflow comes up in the machine, the jam C3205 occurs.
    As I have seen, the entrance area of the horizontal transport section has no sensors to detect a paper. The command should come from the machine.
    When I use the machine without the horizontal transport section and the finisher, everything works perfect without paper jam problems.
    Please excuse my bad english, but I hope you understand what I wanted to say.
  • allan
    RTFM!!
    • 5459
    Re: bizhub C454 with FS-534 jamming C3205 horizontal transport section didn't start
    Was it working before. Did you do firmware. Is there a resonse if you open the finisher door does it show you the doors open?
    Whatever
      • 22960
      My first impression is the the finisher is losing communication with the copier. As a result the MFP intends to eject the paper to the middle tray, but there is a pesky inoperative bridge unit in the way.
      We used to get this all the time when one of our biggest customers would disconnect the full sized finisher to move the machines around, but would then forget to re-connect the cables to the bridge unit. =^..^=
      • Laserbeam
        • Aug 2011
        • 152
        The cause is found!!!
        After replacing the middle tray without success, I opened the finisher and saw a broken detecting plate. After exchange with a new one, all works fine.
        Thanks again to all, who have made the effort to answer me!
          • 22960
          Good catch! Were you able to re-set the existing timing wheel, or was it damaged requiring replacement? This is located in the bridge?
          Thanks for sharing your conclusions. =^..^=
          • Laserbeam
            • Aug 2011
            • 152
            no, I had to renew the timing wheel, because the hold claw was broken. This wheel is located in the finisher (2 of them exists), not in the bridge.
            • kevan750
              • Sep 2012
              • 8
              Do you have the location and part number for this please?
              • Laserbeam
                • Aug 2011
                • 152
                Parts number: A3EPPP7402
                Description: Detecting Plate
                • splblazer91
                  • Jul 2014
                  • 204
                  Take off the lower finisher tray and then remover the cover behind it. Ive had this happen several times. Never replaced one I just use some gorilla glue and have never been called back on one yet.
