C5501 Skew
  • Gaffers01
    • May 2011
    • 335
    [CQ] C5501 Skew
    Hi,
    I have a problem with a customers KM C5501 where it is skewed by about 1mm
    from top to bottom and i cant seem to find any adjustments for this.
    It is happening from all trays and all card stocks, and it is always the same amount of skew.
    Most jobs it is unnoticble but they have started to print business cards and when they cut them it
    looks crap.
    Thanks in advance
    Gaffers01
    • 23007
    Re: C5501 Skew
    Is it an optical skew or a paper skew? =^..^=
    • Gaffers01
      • May 2011
      • 335
      Re: C5501 Skew
      Hi,
      it seems to be an optical skew paper from all 5 trays does the same amount of skew, but how would i check?
      • bachirabouzeid
        • Sep 2015
        • 17
        Re: C5501 Skew
        to adj the image skew of the FD and CD
        to adj the image skew of FD (back side)
        i think that you will always find a skew especially on the bottom right corner
        • Gaffers01
          • May 2011
          • 335
          Re: C5501 Skew
          Genius bachirabouzeid
          I knew there must have been an adjustment for it but could find the correct one in the manual.
          It was the first adjustment that did the job.
          Gaffers01
            • 23007
            Re: C5501 Skew
            If it was the registration section adjustment it was a paper skew, not an optical skew. The way you can tell is to wrap a piece of tape around one of the charge units. You will get a void through that color. Measure the void to the edge of the paper. If it's the same lead to trail, it's an optical skew, because the paper passed through straight. If the void skews you know it's the paper.
            Congratulations on your success. =^..^=
