Bizhub c364e web browser button needs removing
  • mrfuser
    • 1617
    Ok, we have looked high and low how to remove the "web browser" button on the screen for the client. We were able to remove the "pull print" button, but no where can we find the ability to remove this one from the screen.
    Any ideas?
    K
  • copyrooks
    • Oct 2013
    • 209
    Re: Bizhub c364e web browser button needs removing
    menu
    utility
    admin settings
    system settings
    custom display settings
    main menu display settings
    should be on 10 or 11
    • mrfuser
      • 1617
      We only have option 1,2,3,5,6 and 7
      • copyrooks
        • Oct 2013
        • 209
        did u go to page 2 on the right hand side?
        You can also try loggin into web interface
        login as admin
        system settings tab
        main menu default settings
        • mrfuser
          • 1617
          The only thing that shows there are options to choose a theme
          • copyrooks
            • Oct 2013
            • 209
            You are suppose to choose main menu default settings.
            main menu display settings show the theme options.
            I attached a pic for help. Good luck!!
            • Synthohol
              Certified Konica Expert
              • 5824
              turn OFF the web browser in admin, network, web browser setting.
              • mrfuser
                • 1617
                I would love to but that option does not exist in there
                • rrrohan
                  • Sep 2011
                  • 1977
                  Yeah i know what you mean
                  C364e doesnt come standard with web browser in my region and its on the main menu but greyed out.
                  I dont think you can remove it
                  Sent from my SM-G955F using Tapatalk
                  • B0265
                    • Jan 2007
                    • 718
                    If the web browser button is greyed out then a firmware update will fix it.
                    I think it was from function version 7 that the external apps and web browser buttons were removed.
                    • Bix
                      • Apr 2018
                      • 1421
                      I confirm, I removed it with a firmware update
