Konica Minolta C253 (Develop Ineo+ 253) - HDD Error - Enter Service Mode during Error
  • DrogenDiego
    • May 2018
    • 11
    Hey,
    I have read every topic on the net. I have the field service manual etc.
    Recently my printer C253 showed a HDD Error.
    It won't boot and gets stuck at logo screen.
    I went ahead and disconnected the HDD. Then the copier booted again but with the error code.
    When I reinstall the HDD same Error.
    So I tried to fix the HDD on my computer. I ran disk utility repair on my MAC.
    Now the copier shows this error: C - D010
    This reads to
    CD010:
    Hard disk unformat
    So apparently The HDD is formated wrong now. I would like to enter the service Mode to format the HDD from within there.
    BUUUUTTT I can't enter the service mode. Becaus the printer is stuck at the error screen. The Utility button doesn't do anything.
    If I press the utility button during startup, the printer won't startup at all.....
    So anyone has a idea how to enter service mode while an error screen is shown?
    Any help is greatly apreciated!!
    unic0rned
  • lazymangr
    • Feb 2017
    • 115
    Re: Konica Minolta C253 (Develop Ineo+ 253) - HDD Error - Enter Service Mode during E
    you have either go in service mode and reformat the hdd from the machine, or replace hdd or remove it but you have to go in service mode to set hdd disable
    • DrogenDiego
      • May 2018
      • 11
      Yes but HOW to get in Service Mode while the machine displays an error? Can't dismiss the error.
      • tsbservice
        Field tech
        • 8002
        Did you try trouble reset?
        • DrogenDiego
          • May 2018
          • 11
          I can't do trouble reset.
          When I press the utility/counter button during startup, the small dot at the right corner appears.
          But then it hangs on the logo screen. I can't get to the screen with trouble reset.
          • tsbservice
            Field tech
            • 8002
            What was error when you disconnect HDD?
            • DrogenDiego
              • May 2018
              • 11
              When the HDD was disconnected I got error:
              C - D0040
              Hard disk access error
              Unabletocommunicatebetweenthehard disk and printer control board (PRCB).
              • CopierNerd
                • Feb 2015
                • 207
                Simply go to service mode and then "system 2" , set HDD to "not installed". then reboot machine, it will start working.
                if you are having trouble going into service mode, then open right side door and then turn the machine ON. It will not show any error unless you close the door. so leaving the door open, go to service mode with key combinations.
                • DrogenDiego
                  • May 2018
                  • 11
                  Nice try. But unfortunately not (
                  Even with door open the error appears immediately.
                  I attached some photos so you believe me )
                  • Synthohol
                    Certified Konica Expert
                    • 5814
                    put it back in your computer, remove the partition, create a partition but for goodness sakes dont format it, the copier has a different file system than your MAC so format it in the copier.
                    • tsbservice
                      Field tech
                      • 8002
                      Not sure if possible, just an idea. Can you open PSWC typing IP address of machine in a browser?
                      Admin settings-security settings-HDD settings-Format
                        • 14652
                        How long have you waited with the error code? I have had HDD errors and sometimes it takes over five minutes before I am able to enter service mode.
                        • DrogenDiego
                          • May 2018
                          • 11
                          Can't access the webpage. IP is not working. Just blank page.
                          • DrogenDiego
                            • May 2018
                            • 11
                            I didn't format the partition on my mac.
                            I just tried repairing it. But I would assume it makes the same problem.
                            If I create an empty partition with my MAC I highly doubt, that the error message will change. I would prefer not to medle with the HDD. I just need to get into that service mode to format it on the machine itself. Or if exists, find a tool that can format it from my computer. Than I can do that too.
                            • DrogenDiego
                              • May 2018
                              • 11
                              I've had the machine running for an hours with no change in the error code.....
                              IT's the screen of death I can't do anything...
