error code E355 - 0004
  • mubiz
    • Feb 2014
    • 17
    [Error Code] error code E355 - 0004
  • teckat
    • 16083
    Re: error code E355 - 0004
    is that iR1133 an imagePress Series model or just a iR1133
    was there any work performed on this model before E355-004 ERROR
    Try Re-fitting all the harness connections within the control panel assembly
    do u see a Language Switch Shortcut Key- on the display ??
    Language Switch Shortcut, when enabled, is displayed next to the 'System Monitor' button on the device LCD screen as shown in the image below. It allows users to walk up to the device to quickly and easily switch the LCD display to their desired language. This shortcut can be useful if, for example, the device is located in a hotel's business center where people from all over the world want to access the device.
    Configuring the Language Switch Shortcut Key
    1. Go to Additional Functions / Common Settings / Language Switch and the following screen will appear:
    FIGURE 2
    2. Press ON
    3. Select a default language
    4. Select 'Display Shortcut Key' (when this option is selected the button will change from gray to teal in color)
    5. Press OK
    II. Using the Language Switch Shortcut Key
    When a user wants to change the display language they have to click on the Shortcut Key, as shown in figure 1 above, which will bring them to the 'Language Switch' screen, as shown in figure 2 above. From here they select the desired language by highlighting it from the list and press OK. This will return them to the copier main LCD screen where all buttons and text will be displayed in the selected language.
    • mubiz
      • Feb 2014
      • 17
      Thx Teckat. yeah, its just a iR1133 just as in Canon IR1133. it does not have that interface. My buddy and i opened it to the inner board and tried to refit all fibres and other connections, but nothing changed. The fact is that i cannot access the menu/ or service code. Its in Chinese and upside down. Any other alternative? Its as if the control panel buttons are all mute. cant find any button responding or it should first be the service button (*) to respond first? I am puzzled. Please help. thanks.
      • teckat
        • 16083
        Check for a stuck panel key ?
        • mubiz
          • Feb 2014
          • 17
          Cool, will get back to u when i try to figure that out. thanks once again
          • teckat
            • 16083
            Counter Memory, Serial Number and Main Controller PCBs work as a set and are considered the “Soft Counter Circuit”. The Counter Memory PCB is electronically stamped with the serial number from the Serial Number PCB. Neither the Counter Memory PCB nor the Serial Number PCB can be swapped to other equipment.
            The Counter Memory PCB keeps track of the total count, which cannot be erased or changed. The service counters are retained by the Main Controller. These counters can be reset manually through service mode. When the Counter Memory PCB must be replaced, after installing the new one, the new Counter Memory PCB learns the Total Count from the Main Controller. This is retained in SRAM on the Main Controller PCB and held active by means of an on board battery.
            E355 -
            Cause
            Mismatch of serial numbers of three items: Serial Number PCB, Main Controller/ Image Processor PCB (SRAM) and Counter Memory PCB.
            Description
            At power-on, a mismatch of serial numbers among the Serial Number PCB, Main Controller / Image processor PCB and Counter
            Memory PCB was identified (“Prohibited Action”).
            Action
            1. Put back all original PCBs into the equipment! (Depends on original cause of failure)
            2. Do not utilize a used Counter Memory PCB or Serial Number PCB from any other equipment. (If previously used, select
            optional counters 2 through 6 (displayed in “Counter Check”) in service mode:OPTION/USER/COUNTER 2 TO 6
            If original problem was E245 or E247, Soft Counters reset to Zero.
            3. Ensure connector J1023 is connected.
            After “Prohibited Action” has been corrected, perform “E355 CLR”. (FUNCTION>CLEAR>E355-CLR) then cycle power off and on.
            (For “70” series and later see Note #4. For imageRUNNER 1023/ 1023N/1023iF/ 2016/ 2020/ 2016i/2020i see step # 10 under
            “Servicing”).
            All others, Counters are retained.
            Serial Number PCB is a matched board with the Counter Memory PCB and cannot be swapped with any other equipment.
            On newer models from Canon (as of this writing, all “70” series and iR3530 series), to clear an E355
            or E354 code, you must enter Service Mode Level 3 (see Notes #3 and #4). DO NOT ADJUST ANYTHING ELSE IN THE SERVICE MODE LEVEL! Doing so will have an adverse affect on the machine
            Note #3: E354:
            If, after replacing the Counter Memory PCB, an error code E354 is displayed, enter Service Mode Level 3 and perform an E354 Clear as follows:
            Additional Functions button then #2/8 buttons together then Additional Functions button
            Additional Functions button then #1/9 buttons together then #3 button
            COPIER>FUNCTION>CLEAR>E354-CLR
            Turn OFF and then ON the equipment
            Note #4: E355:
            If after replacing the Counter Memory PCB, an error code E355 is displayed, enter Service Mode Level 3 and perform an E355 Clear as follows:
            COPIER>FUNCTION>CLEAR>E355-CLR
            Turn OFF and then ON the equipment.
            • mubiz
              • Feb 2014
              • 17
              Am afraid, no button is stuck, buddy.
              Any other idea?
              Am so stuck
              thx
              • teckat
                • 16083
                Any other idea?
                Am so stuck
                thx
                U may need to reload firmware
                but first>>>
                go into service mode> COPIER > OPTION > BODY>LOCALE
                before doing a CLEAR > CHECK THISLANGUAGE SETTING
                Display/adj/set range 1 to 8
                1: Japan, 2: North America, 3: Korea, 4: China, 5: Taiwan, 6: Europe,7: Asia, 8: Oceania
                Default value 1
                LOCALE Caution :
                Since COPIER> FUNCTION> CLEAR> ALL is executed when changing the location, the setting information of user mode, service
                mode, etc. is initialized.
                The setting information of this item is not initialized.
                Default value 1
                Related service mode COPIER> FUNCTION> CLEAR> ALL
                COPIER> OPTION> BODY> SIZE-LC
                SIZE-LC
                Setting of paper size configurationAdj/set/operate method
                1) Set the location under LOCALE.
                2) Enter the setting value under SIZE-LC, and then press OK key.
                3) Execute COPIER> FUNCTION> CLEAR> ALL.
                4) Turn OFF/ON the main power switch.
                Caution Since COPIER> FUNCTION> CLEAR> ALL is executed when
                Display/adj/set range 1 to 4
                1: AB configuration, 2: Inch configuration, 3: A configuration, 4: AB/
                Inch configuration
                COPIER> OPTION> BODY> LOCALE
                • mubiz
                  • Feb 2014
                  • 17
                  Re:Error code E355 - 0004
                  Hey guys, please i would like to know anyone out there with my error experience (E355 - 0004) on Canon iR1133 UFRII LT.
                  I cant even get to service mode. I have tried to refit every cable or fibre.
                  I am almost giving up.
                  Please come to my rescue.
                  • teckat
                    • 16083
                    Re: Error code E355 - 0004
                    have you tried to see your printer using RUI ???
                    type your printers IP Address into URL window
                    example below
                    LANGUAGE = Manage languages used in panel / Remote UI and font data.
                    Main controller PCB > replace it
                    re-load the firmware
                    • mubiz
                      • Feb 2014
                      • 17
                      Re: Error code E355 - 0004_Lost hope
                      Hey, thanks for your concerned. I am afraid my printer has no IP address. Btw, My copier is a 3in1 (copier, printer & scanner). U suggest i replace the PCB? So how much are we talking about and how many boards do i need to replace to get the machine back on track? I hear a combination of boards need to be bought together. Which ones could these be? How much will it cost me to replace these boards and where is it possible to access them at a fair price? I live in Uganda, East Africa. Thanks.
                      • teckat
                        • 16083
                        why can't u get in service mode ???????????
                        what are u doing to get in service mode ????
                        LCD Display image is reversed and upside down
                        Try removing & Re-fitting all the harness connections within the control panel assembly
                        what have u tried so far ?????????????????????
                        post a picture of your display panel
                        • mubiz
                          • Feb 2014
                          • 17
                          Oh surely, i have failed to get into service mode.
                          I shall surely send u the image of my control panel in about 10hrs time.
                          thanks for your concern once again.
                          • mubiz
                            • Feb 2014
                            • 17
                            Re: Error code E355 - 0004_Image displays
                            just posted some images of my control panel. and the display on the screen (Chinese language and upside down)
                            • teckat
                              • 16083
                              ______;
                              That should not prevent u from entering servicr mode
                              Are u a tech ?---have u tried removing panel connections ?
                              Have u unpluged connections on main pcb,s ?
                              What have u tried to do/ Printers don,t change language overnight
