error code E355 - 0004
  • mubiz
    • Feb 2014
    • 17
    #16
    Re: Error code E355 - 0004_Image displays
    Hey, Yeah, i have done all that, i have opened to the last board inside, reseated all cables and fibres, i have opened all pcbs, but no change. Actually , i have used this machine for 1 and half years, thats when it changed and started bringing such error codes. Anything else i havent done yet?
    • teckat
      • 16084
      #17
      Re: error code E355 - 0004
      Re-Load Firmware ;>]
      • mubiz
        • Feb 2014
        • 17
        #18
        thx. please tell mi how i can reload firmware successfully. thx
        • teckat
          • 16084
          #19
          contact your local authorized Canon dealer,
          have the following information available:
          1-Product name =imageRUNNER 1133)
          2-Serial number (a character string of 3 letters and a 5-digit number; located on the rating label on the rear side of the machine or on the label on inside of the machine's front cover)
          3-Details of the malfunction
          or did u Try this already
          Specifying the Screen that Is Displayed after Auto Reset Is Performed
          Press [*] (Menu).
          Select <Timer Settings> using [^] or [v] and press [OK].
          Select <Screen After Auto Reset> using [^] or [v] and press [OK].
          Select <Default Screen> or <Selected Screen> using [^] or [v] and press [OK].
          <Default Screen>=The screen selected in "Setting the Default Screen" is displayed.
          <Selected Screen>The screen displayed prior to auto reset is displayed again.
          Press [*] (Menu) to close the menu screen.
          Specify the screen to display after auto reset is performed or when the machine is turned ON.
          IMPORTANT:
          The screen that is displayed after auto reset is performed
          The displayed screen varies depending on the <Screen After Auto Reset> setting specified. It has a higher priority than the default screen specified here.
          <Default Screen>: the screen specified here is displayed.
          <Selected Screen>: the screen that the machine returns to after auto reset.
          Press [*] (Menu).
          Select <Preferences> using [^] or [V] and press [OK].
          Select <Display Settings> using [^] or [v] and press [OK].
          Select <Select Default Screen> using [^] or [v] and press [OK].
          BEFORE U SELECT THIS DEFAULT SETTINGS
          IN THIS MENU U WILL SEE A LANGUAGE SETTING (select ENGLISH )
          select it & choose your language setting/ & press [OK]
          after setting LANGUAGE > go back to
          Dispplay Settings Menu
          Select the screen you would like using [^] or [V] and press [OK].
          <Copy>
          Display the copy mode screen.
          <Fax>
          Display the fax mode screen.
          <Scan>
          Display the scan mode screen.
          <USB Direct Print>
          Display the USB direct print mode screen.
          • teckat
            • 16084
            #20
            DID U TRY THIS / U SHOULD BE ABLE TO SELECT THE
            [*] (Menu)
            Switching the Display Language (Operation Panel or Remote UI)
            Switch the display language used for the operation panel, report, or the Remote UI.
            1-Press [*] (Menu).
            2-Select <Preferences> using [^] or [v] and press [OK].
            3-Select <Display Settings> using [^] or [v] and press [OK].
            4-Select <Language> or <Remote UI Language> using [^] or [v] and press [OK].
            <Language> Specify the display language used for the operation panel and reports.
            <Remote UI Language> Specify the display language used for the Remote UI.
            5-Select the language using [^] or [v] and press [OK].
            6-Press [*] (Menu) to close the menu screen.
            Or in the
            [*] (Menu) u could try to
            Initializing the Menu
            Initializing the Settings
            Restore the following settings to the default settings separately or together.
            Preferences
            Timer Settings
            Common Settings
            Copy Settings
            Fax Settings
            Scan Settings
            USB Direct Print Settings
            Printer Settings
            Initialize All
            Select <Initialize Menu>
            Select the single item above or select Initialize All
            Select YES/NO
            Initializing is performed when u highlight YES or NO
            • mubiz
              • Feb 2014
              • 17
              #21
              thx but unfortunately, in Uganda i got no idea if we got a dealer in charge of technical issues
              • teckat
                • 16084
                #22
                __;
                Did u try to just select the *Menu key ?
                Like i posted above\ it brings u in the regular adjustments i show
                I can see the menu key in your pic
                • mubiz
                  • Feb 2014
                  • 17
                  #23
                  Thx buddy, The main issue is that i cant access or enable any key on the control panel. When i switch the power on, the copy button lights and the error button only. the start button just blinks dimly on powering and it goes off. No button lights at all apart from the copy and error button. All wires and fibre cables have been reseated. still stuck.
                  • teckat
                    • 16084
                    #24
                    U should be able to access the MENU* key even in error state////
                    u could have a stuck key o panel////
                    did u pull off panel >take apart to inspect ????????
                    have u checked your wall voltage supply for proper supply ?
                    who installed this unit / must have a company that services Canon near
                    • mubiz
                      • Feb 2014
                      • 17
                      #25
                      Yeah, u have checked all the keys, they are ok, none is stuck.
                      The main power is ok.
                      About the local dealer, they are in the capital though they got no idea abt the problems. All they tell me is may be if i buy other boards.
                      I will try to clean the buttons down using the contact cleaner fluid. Do u think its the best or do u have an alternative?
                      Please help and translate for me these words on the image attached. They are the ones shown on the display window on my copier.
                      thanks
                      • teckat
                        • 16084
                        #26
                        thanks
                        do not spray or use any solvent on buttons
                        • teckat
                          • 16084
                          #27
                          what happens -----when u press this MENU KEY
                          power off printer/ remove printer left cover>remove main controller cover>remove flat cables & connectors as shown in pic below
                          now re-seat everything> be careful with those flat cables( seat them firmly in )
                          put covers back on/ power up printer see if u can get into menu /
                          u may get lucky & check-----or need to>
                          Re-Set the location group and paper size group.
                          • COPIER > OPTION > BODY > LOCALE (setting the location group)
                          [Setting value]
                          1: Japan, 2: North America, 3: Korea, 4: China, 5: Taiwan, 6: Europe, 7: Asia, 8:
                          Oceania
                          • COPIER > OPTION > BODY > SIZE-LC (setting the paper size group)
                          [Setting value]
                          1: AB configuration, 2: Inch configuration, 3: A configuration, 4: AB/Inch configuration
                          • mubiz
                            • Feb 2014
                            • 17
                            #28
                            Anyone u know who has had my problem of not being able to get into service mode but has succeeded?
                            I mean my canon iR 1133 error code E355-0004, display in Chinese or Japanese and upside down?
                            Please link me to them.
                            Am desperate.
                            • teckat
                              • 16084
                              #29
                              Am desperate.
                              This iR1133 is like the imageCLASS D1300/ same animal in USA
                              Check these two connectors on
                              Main Controller PCB-------------unplug >power up printer>then power of printer and plug back into Main PCB> now power back up Printer
                              J916==SERIAL DEBUG MONITOR
                              J902=for Control Panel
                              do u have a USB memory or other USB device connected If yes REMOVE IT !!!!!!!!
                              do u have a PC or Laptop connected to Printer ?????
                              Did u do the procedure I posted above about removing & re-seating the connections ?????
                              What happens when u press the MENU Button
                              Removing the Control Panel// See pdf
                              Removing the Main Controller Board
                              u don't have to remove the BOARD>>>Just remove the connections & re-seat them
                              Removing the Main Controller Board.pdf
                              • mubiz
                                • Feb 2014
                                • 17
                                #30
                                Thanks buddy.
                                i will give u feedback
