6030 duplex
  • blsquires
    • Nov 2008
    • 342
    6030 duplex
    i have a km6030 in a school ,the problem is on a run using duplex and staple it gets a slight fold on the front edge of side two.it folds before side two is printed as the copy goes over the fold .it dosnt happen on normal copying just side two duplex .i have replaced the songe rollers and stripped the duplex uint and cleaned all the other rollers. any ideas please.
    thanks in advance brian
    • 23008
    You'll want to replace the duplex switchback roller (302FB19401). When it wears the roller wears conical.
    When it's new it's 66mm circumference. As it wears, the rear wears faster than the front. When the difference becomes 1.3mm (65.3mm at front, 64mm at rear) the paper skews so badly that when inverting for exit or duplex, the rear edge flips, causing J60, J62, J63 jams. When stapling, the flipped corner prevents the paper from setting in the stapling tray properly. =^..^=
    • blsquires
      • Nov 2008
      • 342
      thanks for the heads up i will order the switchback roller.
      brian
      • blsquires
        • Nov 2008
        • 342
        blackcat4866 thanks very much for the info .it was spot on ,who would think that one little roller could cause all those problems .and you was right about one end wearing quicker than the other .i used a vernier gauge to check the old one and there was a difference as you said .so many thanks.
        brian
          • 23008
          Since all paper output is delivered face down, every single page (and duplex twice), must pass through the duplex switchback. If I thought Kyocera was listening I'd say "Hey Kyocera, why don't you install a solid rubber roller the whole width of the paper? Sure, it would cost more initially, but there would be no J60, J62, J63 jams, and that roller would probably never need replacing." Who knows. Maybe someone over there is listening...
          I'm glad that I could help. =^..^=
          • cysec
            • Jun 2008
            • 21
            Re: 6030 duplex
            Hey, just a few questions, you refer to the roller 302FB19401, which is the switchback roller, and yet you give mesurements of 66 - 64mm, which don't make sense. I could see if you were talking about 302FB00040 which is the refeed roller, but the switchback roller is only ~20mm diameter to begin with. I would rather not order the wrong roller, so which is it?
            • Kidaver
              Ghoulscout
              • Apr 2011
              • 912
              Re: 6030 duplex
              Blackcat gave the right part number. It is that roller for sure as I've replaced my fair share of them. On top of replacing that roller always make sure the plastic roller and shaft that is above it is clean and rolls easily.
              "In a cruel and evil world, being cynical can allow you to get some entertainment out of it."
                • 23008
                Re: 6030 duplex
                Circumference is the distance around the outside. Diameter is the distance through the center
                C = 2 pi R = pi D where pi = 3.14159265
                There are three reasons I measure circumference:
                1) You can measure circumference without removing the roller. Cut a strip of paper ~5mm wide and add a piece of scotch tape to the end. Stick the tape along the edge of the roller you'd like to measure and roll the paper around until it laps. Make a mark across both layers of paper. Remove and measure.
                2) It's not so easy to mic soft materials like rubber, plus it would have to be removed.
                3) Personally I feel that I can measure accurately down to 0.2mm. To measure diameter to the same degree of accuracy you'd have to measure the diameter down to 0.063661977mm. If your millimeter scale had ten more marks between 1.0mm and 2.0mm, 0.06 would be ~ 1/2 of one of those marks. If you can do that, you've go much better vision than I do. =^..^=
                • Masterchief
                  • Apr 2011
                  • 280
                  Re: 6030 duplex
                  Another spot on post by Blackcat, have also changed the same part to solve this issue.
                  Great post
                  Masterchief
                  sigpic
                  • cysec
                    • Jun 2008
                    • 21
                    Re: 6030 duplex
                    Oh wow, I can't believe I mixed that up. Just couldn't seem to get my brain to fully engage yesterday, might be a lack of coffee. Thanks again, the part has been ordered.
                    • farhanali79
                      Re: 6030 duplex
                      hello friends, I am having the same problem but in my case, I have observed that when I set the original to A4 and use A4 paper for duplexing, it jams in the duplex unit with one side printed. When I pull out the duplex unit, the paper is stuck between the duplex guides and the gap between the guides is only 11.5 inches instead of 11.75 inches. so the paper can't pass through.
                      Then just for testing purpose, I set the original size to letter and print on the A4 paper and it didn't jam and upon having a look on the duplex guides, I found out that the gap was wide open. repeated this for 100 duplex prints so I don't think the rollers are the culprit
                      The guides in the duplex unit are not recognizing the paper size correctly and pushing the paper in length which is causing the jam. What shall I do to maintain the correct gap between the duplex guides? do some adjustments in maintenance mode or clean some sensors? I have already cleaned the switchback roller and the white roller.
                      PS. The jam also occurs when I print from my computer.
                        • 23008
                        Re: 6030 duplex
                        Did you look at the duplex switchback roller? =^..^=
                        • farhanali79
                          Re: 6030 duplex
                          yes it's like new
                            • 23008
                            Re: 6030 duplex
                            And you measured? =^..^=
                            • farhanali79
                              Re: 6030 duplex
                              I did not use a vernier but I can tell it's not worn out in conical shape. do you suggest me to replace the SWB roller?
