C2700
  • ss12
    • Jul 2008
    • 289
    [Error Code] C2700
    Got a problem with a taskalfa 250ci.threw a 2700 code, replaced the transfer unit,no joy then engine pwb, finally the fuser unit still not fixed.the strange thing is,is that when you switch the machine on you can hear the release motor continually turning until the error Code comes up,and in simulation the motor also does the same thing.it's as though the machine isn't receiving the signal that the motor isn't in the correct position. By the way firmware is the latest.Any ideas all suggestions welcome?
  • copygirl
    • Apr 2008
    • 75
    Re: C2700
    I just had that C2700 yesterday. The info I read on it was to upgrade the firmware and if that didn't work to change the transfer unit. They've made changes to the gears on the unit. The release motor is on the transfer unit itself. Sorry you're having trouble. Mine reset and I upgraded the firmware. Haven't heard from the customer so I guess I just got lucky. If you need the document on the C2700 let me know. Good luck.
    Ginger
    • ss12
      • Jul 2008
      • 289
      Transfer unit is the latest one,machine has all the modifications,and the firmware is ver12,tried with the old transfer unit,still the same problem
        • 23008
        Re: C2700
        On my machine it was the old style transfer unit. I was able to clean, lubricate, & re-shim the color transfer shift drive. The engine PWB was the next logical choice.
        All that's really left is a few feet of wiring. Perhaps a pin has pulled out of a connector? Or a wire pinched? I think I'd spend some time pinning out the harness. It sounds as though the wires you're looking for are for the color transfer shift home position sensor. =^..^=
        • ss12
          • Jul 2008
          • 289
          Re: C2700
          UPDATE:the problem turned out to be a damaged pin on the transfer unit connector (machine side).Thought that i`d checked and double checked that,obviously not,oh well live and learn!!
            • 23008
            Re: C2700
            Congratulations! These kind of harness problems require real persistence to find.
            (this is a compliment) =^..^=
            • tmaged
              Owner/Service Manager
              • Oct 2008
              • 1887
              Re: C2700
              Thanks for updating the thread. I did maint A & it must've pushed a pin in slightly when I put the new belt unit in. It's not a quick fix, but I got it taken care of.
              Hope that helps !
              -Tony
              www.dtios.com
              Become a fan on Facebook
              • Tonerkiller
                • Oct 2012
                • 668
                Re: C2700
                Good info this thread saved he a lot of time. I also had the code and the pushed in pin.
