Remember when ?
    • 23009
    #31
    Re: Remember when ?
    Originally posted by ZOOTECH
    I remember my dad told me "do not crank the handle" with your thumb around the handle; a back fire would take your thumb off!
    I'm a little too young to remember this, but my buddy tells me that when they were still plowing with the Ford Model T's, you were to cup your hands around the crank. Never wrap your thumb around the crank. That handle could knock you on your ass, and often did. =^..^=
      • 14812
      #32
      Re: Remember when ?
      Originally posted by KenB
      In 1954, this was what the "home computer" of 2004 was expected to look like:
      What the hell is the captain's wheel for? Was it drive-able?
      • subaro
        • Oct 2010
        • 1274
        #33
        Re: Remember when ?
        I had a '64 Dodge Dart with a push button tranny.
        You flipped a small lever to the right to put it in Park.
        The zephyr i mentioed earlier on had the exact same push button type automatic transmission like this one. Your car in this video KenB.
        The world without YOU TUBE would be different. Learnt and seen so many things there and things have not seen in ages.
        • Coptech
          worker drone
          • 460
          #34
          Re: Remember when ?
          64 and prior, torquflite transmissions were pushbutton. 65 brought the standard shifter. also I believe the pushbutton trans may have been iron instead of aluminum but not real sure about that.
          • subaro
            • Oct 2010
            • 1274
            #35
            Re: Remember when ?
            What about your electric billing. remember seeing the bill in this format only and not knowing what all those numbers meant. this was about in the 70's or so. punch cards.
            • ZOOTECH
              Senior member of CRS
              • 3375
              #36
              Re: Remember when ?
              I've worked on those early in my career; had a service call about the machine always putting an extra space at the end. After checking machine out, I had the female operator demonstrate how she was entering the info. All was good until she leaned over the keyboard to check her work - yes, she had ample breast hitting the space bar. Blushing to a deep red, I had to explain 'where' the problem was.
              • NeoMatrix
                Senior Tech.
                • 3513
                #37
                Re: Remember when ?
                I remember starting the old model T tractor( Fordson?) and plowing the fodder paddock for my uncle.
                I believe they where kerosine start and then you manually switched them over to diesel.
                You had to pull the decompression lever and wind the crank handle until you found TDC. Then crank like heck an hope it did'nt kick back and take your hand off... And they did kick back. I was only a small lad an I would jump up in the air to push the crank handle down with all my weight to get the crank moving. I remember a sore hand a few times from moving the crank to slow.
                • subaro
                  • Oct 2010
                  • 1274
                  #38
                  Re: Remember when ?
                  Well i had a yamaha xt175 semi trail bike and cranking you would get kick back that was nasty. I later upgraded to a yamaha xt500 semi trail and the kickback from those were bone breaking stuff. awesome bike, but hated it for the cranking. The 175 was just a nice bike to get around. have not rode a bike in years and don't know if cranks are still the norm. this was about 35yrs ago and bike technology may have improved quite a bit by now. must go to a bike store some day.
                  • CompyTech
                    Super Tech
                    • Feb 2011
                    • 706
                    #39
                    Re: Remember when ?
                    Originally posted by Iowatech
                    I always liked the odor of ozone that would come out of tube radios or TVs.
                    I'm a too young for tube radios and tvs, but I remember the CRT TV's growing up, the static that would be on the glass.. I had one memorable experience as a kid when I was tasked to clean the big 32 inch Sharp using Windex and a rag.
                    • 20 year tech
                      • May 2014
                      • 577
                      #40
                      Re: Remember when ?
                      Cars had only am radios or no radio at all
                      Drive in movie theaters
                      the little Fotomat booths in shopping center parking lots (before Malls)
                      • fixthecopier
                        ALIEN OVERLORD
                        • 4713
                        #41
                        Re: Remember when ?
                        I remember having to go outside and manually turn the antenna. Getting one of those things that did it for you was awesome.
                        • gneebore
                          • Feb 2010
                          • 555
                          #42
                          Re: Remember when ?
                          Learned how to fix those keypunch machines over 40 years ago. Even had a hand punch to make diagnostic cards for the verifying machines. Kept the hand punch for years and used to put a random punch in my electric bill and mail it back that way.
                            • 23009
                            #43
                            Re: Remember when ?
                            I've seen one of these little turntables way back ... must have been from the 50's. I understand that they worked about as poorly as you would expect. =^..^=
                            • KenB
                              Geek Extraordinaire
                              • Dec 2007
                              • 3944
                              #44
                              Re: Remember when ?
                              [ATTACH=CONFIG]31473[/ATTACH]
                              I remember seeing these in a J.C. Whitney catalog.
                              I feel old....
                              • subaro
                                • Oct 2010
                                • 1274
                                #45
                                Re: Remember when ?
                                I feel old....
                                Yeh, KenB feel for you , because i could only remember the 8 track players and static radios.
