Good tool magnetizer?
  • lencombs
    • Sep 2015
    • 8
    Anyone know a good tool magnetizer? I have a new Katun tool set and the magnetizer it came with just isn't strong enough. Screws are falling off, it's like playing a game of operation trying to make sure I don't barely touch something to make the screw fall off my screwdriver.
  • allan
    RTFM!!
    • 5462
    Re: Good tool magnetizer?
    Wind a long piece of insulated wire around the shaft of your screwdriver and use you car battery by connecting one end of the wire and taping the other end on the other terminal.
    Sometimes its to effective and the screwdriver will get stuck on all the metalwork in the machine.
    Whatever
    • CraigW
      • Dec 2010
      • 417
      Had my best luck with 4 magnetron magnets stacked up.
      I let it suck down the middle to the bottom and leave it overnight once every couple of weeks.
      • DavePo
        • Jul 2008
        • 305
        I use a magnet out of a old HDD. Put it in a pouch behind my screwdriver and every time I put it away and remove it gets magnetized.
        • qbert69
          • Mar 2013
          • 1152
          I got a couple of the plunger style door magnets that are stuck to my magnetic parts dish that once in a while I stroke the shaft (...sounds bad doesnt it?!....LOL!) of my screwdriver with!!!....the strong rare earth magnets such as the neodymium and cobalt magnets are the best!
          Wanna see something cool???:
          REACH FOR THE STARS!!!
          Konica Minolta Planetariums!
          • TheBlueOrleans
            • Aug 2012
            • 232
            Originally posted by mrwho
            I use the HDD magnets to magnetize my screwdrivers. Also my sister loves them to make tools to clean the inside of big jars (one magnet on the outside, other on the inside, a cloth in between...)
            This, from the McGyver thread.
            (is it "mick" or "mac"? I can never keep that straight.)
            Somewhere there is a tree working hard to produce oxygen for you to live, NOW GO APOLOGIZE TO IT!
              • 23010
              I've seen the magnet trick done to clean large fish tanks. Wrap two magnets in cleaning cloth. Put one inside directly across from the outside one. It was a cylindrical tank 1.3m tall by .6m diameter. The cleaner guy used a swirling motion, occasionally spraying glass cleaner on the outside. (The inside seems to stay wet enough ... at least the fish think so.)
              It was in a hospital waiting room, and it's amazing how intriguing it is to watch the fish tank be cleaned when you've only got 5 hours to wait. =^..^=
              • NeoMatrix
                Senior Tech.
                • 3513
                You can buy commercially available fish tank cleaning magnet products as described.
                I've seen the same glass cleaning magnets used on a large cubic shaped fish tank. The tank was located in a foyer of a public building. The owners must have grown tied of cleaning the algae growth off the tank, so they left the glass cleaning magnets in place on the fish tank.
                They placed a sign on the tank "Please clean the glass so we can see you" for the fish. It must have worked because every kid that came along (me included) move the cleaning magnets back and forward cleaning the algae off the glass. After some perseverance, I found that there is a trick to actually cleaning the fish tank using the magnetic sponges and working both together.
                  • 23010
                  Back to the tool magnetizer issue:
                  I have used primarily magnetized screwdrivers with replaceable bits for my entire career. I've got a few odd screwdrivers for specific purposes 18", 30", stubby, offset ... and they do not hold magnetism for any length of time. Every time I need to use one of these special purpose drivers, I have to magnetize it. =^..^=
                  • JR2ALTA
                    • Feb 2010
                    • 2033
                    The classic magnetizer is great IF you can fit it into the screwdriver slot of your tool pallet. In other words, every time you insert/remove your driver it re-magnetizes.
                    • ZOOTECH
                      Senior member of CRS
                      • 3375
                      Originally posted by JR2ALTA
                      [ATTACH=CONFIG]33232[/ATTACH]
                      Keep this in a zip lock bag to keep all the other "debris" from getting in the way.
                      • NeoMatrix
                        Senior Tech.
                        • 3513
                        Yourself and ZooTech have it....
                        I was feeling too lethargic to take a phone-pix of my own mag-tool and post it... I hate cold weather...
                        When it becomes dirty I clean my same mag-tool out with an air compressor.
                        Okay now humour the forum with the method you use to magnetise the driver ?
                        Leaning down over your tool case with your mag-tool and driver in hand between your legs moving your elbow back and forth, with your back to the office staff, makes for some interesting raised eyebrows and conversations from office staff...
                        Hint for the newbies:
                        Don't magnetise your screw driver in the closed isolated copier room, just incase staff walk in...
                        • igi
                          • 1507
                          and the swipe on the outside demagnetizes.
                          magic
                          • ZOOTECH
                            • 3375
                            Well, sliding it in-and-out, in-and-out is always good form. 🙈
                            • allan
                              RTFM!!
                              • 5462
                              Really use a car battery and good wire.
                              You can hang your tech screwdriver upside down from anything metal enough.
                              Using that on a Ricoh MP6500 poses a real problem with that thing sticking everywhere!
                              Not for daily application but really fun to do with someone un-expectant of this stickydriver .
                              Whatever
