Electronics
  • allan
    RTFM!!
    • 5462
    Electronics
    Think its a good idea to start an electronics thread. Hope there are guys here interested in this stuff.
    Anybody ever used copier electronics for something useful?
    Here is the first part of an ozone generator i am making from a HV transformer found on a KM B601.
    Got it up to 3.5KV i guess. More KV would be nice.
    Anyone played with HV supplies before?
    Whatever
  • habik
    • 2013
    Re: Electronics
    Hehe nice.
    Sent from my GT-I9300 using Tapatalk
    Firmwares HERE
    • DigiMan
      • Jan 2013
      • 262
      Re: Electronics
      Heh made a fully functional elevator model from scratch about 6 years back.
      Making the PS for it was actually not really hard but making the parallel cables
      and programming the integrated chips was a pain in the ass.
      If i get the chance il send you a pic from a wah pedal i made from scratch for my guitar
      using some parts from our beloved MFP's.
      My father would love to join these kind of discussions
      I don't like the new copier I just bought. It says "put face down" but every time I do it, it blinds my eyes.
      • allan
        RTFM!!
        • 5462
        Re: Electronics
        Wow, an elevator model. How many landings?
        Whatever
        • DigiMan
          • Jan 2013
          • 262
          Re: Electronics
          4!,wanted to do 5 but i had a problem with the code accepting
          odd numbers,only worked with even,didnt figure it out eventually
          • allan
            RTFM!!
            • 5462
            Re: Electronics
            Did you have call buttons and a COP(car operation panel)? Would like to see this thing.
            Before i got stuck in this job. I use to draw and manufacture elevator components.
            Where did you get the idea from?
            Whatever
            • habik
              • 2013
              Re: Electronics
              Nice. Did you use the mechanics from finisher lift?
              I had quite a few put aside from old Kyo 6030 finishers to use for PV panels project and glass house ventilation, left it all in previous job. Time to restart the project.
              Sent from my iDon't believe in marketing device using Tapatalk
              Firmwares HERE
              • Iowatech
                Not a service manager
                • 3930
                Re: Electronics
                I don't think I should comment here as the closest thing I've made was a travel mirror out of a dead HDD.
                People asked me why, and I didn't have a good answer.
                  • 22999
                  Re: Electronics
                  Two come to mind. I don't think any of these things really qualify since they're basically mechanical devices:
                  I made an automated tea infuser. It uses the two Canon primary wire cleaner motors and two DPST switches to drive Mita lens reduction gears. It drops the mechanism into two teacups then cycles once per second vertically ~40mm. I wanted to be able to preset a timer in which the machine would retract from the cups, but never did figure that part out. The device has been in service for 20 years of daily use, with only 1 motor failure and one switch failure.
                  Inertial brake light: I used 9 Mita reed switches inset in a PVC housing.. When you brake or accelerate the inertia moves a counterweight, swinging a magnet past an increasing number of reed switches. Each reed switch is wired to an increasing number of LEDs. So the harder you brake or accelerate the more LEDs light. It served two purposes as far as I can tell. 1) as a warning to following vehicles. 2) as a personal reminder to drive in a more restrained manner, minimizing the hard stops and starts. (It's still around here someplace.) =^..^=
                  • allan
                    RTFM!!
                    • 5462
                    Re: Electronics
                    I am thinking of making a grill out of fuser lamps. I have 4 KM B1250 fuser lamps coming out soon.
                    Whatever
                      • 22999
                      Re: Electronics
                      You'd need to shield them from the grease, but I'd imagine they'd be very effective, and easy to regulate the temperature. =^..^=
                      • Lance15
                        • Jun 2015
                        • 1086
                        Re: Electronics
                        I've started fixing LCD monitor power supplies. Couple of new caps and they work like brand new again! Fixed one of the old Dell OptiPlex GX270 mainboards MANY years ago. Again, caps. Worked like new.
                        • allan
                          RTFM!!
                          • 5462
                          Re: Electronics
                          Jip with glass I imagine. Pyrex or hardened of sorts i was wondering if analogue platen glass would work?
                          No fancy tings on here. Just a timer of sorts. Its going to be on or off.
                          Then a dimmer. I hope to use duty cycle control.
                          Should be good for grilled cheese or lamb.
                          700w a bulb X 4. 2800w that should be just enough to toast a breaker or 2.
                          Whatever
                          • subaro
                            • Oct 2010
                            • 1274
                            Re: Electronics
                            Removed cover from hard drive. Cut 2000 grit sand paper and stuck it on the disk and you can put a nice edge to that knife you spend hours trying to hone. You can use different size sand paper disk to get your knife from dull to razor sharp in quick time. Also use it for a general grinder of sorts.
                            Of course you have to power it up with a 12v power supply, which any old desktop computer power supply would do.
                            • allan
                              RTFM!!
                              • 5462
                              Re: Electronics
                              Whatever
