Paper Dust
  • Santander
    • May 2009
    • 768
    Paper Dust
    Had a call a couple of weeks ago for a copy quality issue at a municipal customer and found a broken charge wire on the grid of a Kyocera 5050. The charge grid was replaced and the unit thoroughly cleaned, including the wiper on the registration roller. The unit was coming due for a PM so informed the customer we would be back the next day to do the full PM. Since they were in the midst of they budget cycle they requested that we delay it for a few days until they were done printing their budgets and proposals. OK! Returned 3 days later as requested to do the PM and found the paper dust accumulated on the registration roller cleaning assembly as shown in the attached pix. They had run 6,300 pages in the three days and this is what it looked like. We also have had an increase in the number of calls for "squeaks" only to clean bushings of "paper dust" and re-lube them to solve the squeak.
    Anyone else seeing this problem?
  • NeoMatrix
    Senior Tech.
    • 3514
    Re: Paper Dust
    You've post a CQ problem into the Rant's and Raves forum.
    You may like to delete this post and move it over to the Kyocera forum.
    You'll most likely get a quicker response.
    • habik
      • 2013
      Re: Paper Dust
      Paper dust is from s%&t paper.
      Byting on bits.
      Firmwares HERE
      • qbert69
        • Mar 2013
        • 1152
        Re: Paper Dust
        Interesting!.....as they say, "You Get What You Pay For"!
        Anyway, I had a location (a church) that had custom offset printed bulletins.
        Long story short, the printer had used so much "offset powder" (helps the ink dry and keeps pages from sticking together) which is kind of like talcum powder on the pages that it would foul the pick up feed rollers making them slick and unable to pick up the paper to print!...referred the customer back to the printer to have their custom job reprinted with LESS offset powder!...DOH!
        REACH FOR THE STARS!!!
        Konica Minolta Planetariums!
          • 36887
          Re: Paper Dust
          It is not a CQ poet. It is a rant about paper dust from cheap crappy paper.
            • 36887
            Re: Paper Dust
            People think " paper is paper" what they don't know is.. cheaper paper has a lot of "powder" to keep the sheets from sticking together..and you will also find there are lots of paper slivers in the cheaper paper also
            Tell your customer to switch to a higher grade paper ( will reduce jams and the issue you stated)
            The problem is t hat he said it was "a municipal customer". That means city government. That means very tight budget. Also usually means that they are expected to support local businesses. I have a print shop at an elementary school district with 2 production machines. The person in charge of the print shop has worked for years for commercial printers. He know the importance of quality paper. I found a source that provides a paper that is superior to what you get from Office Depot, etc, and costs less in the quantity he needs. He orders bright white letter size 20# bond by the truck load. Lasts him just over 1 year. Print shop is a one end of their warehouse so he has plenty of room for storage.
            • Kidaver
              Ghoulscout
              • Apr 2011
              • 912
              Re: Paper Dust
              That's all? Man you should have seen some of the school machines I had to go clean when I first started in this field. Mountains of paper dust piled up on that open area behind that felt cleaner. Schools around here get "donated" paper from the paper mills...in other words the crap they can't sell.
              "In a cruel and evil world, being cynical can allow you to get some entertainment out of it."
                • 22942
                Re: Paper Dust
                Typical. You'll get a new camel hair brush in the kit.
                I had a Sharp Dragon I series that was paper skewing and jamming at the registration roller. There was so much paper dust after only 50K that the registration roller would not turn at all. Worst paper ever.
                • allan
                  RTFM!!
                  • 5459
                  Re: Paper Dust
                  Yuck. Reminds me of a KM 500's paper dust cleaner.
                  Whatever
                    • 14406
                    Re: Paper Dust
                    I had exactly the same problem at a church. Ledger sized offset printed bulletins. Every Thursday I would have to go clean the vertical transport rollers. Eventually I MacGuyvered a pad system to brush the dust off the rollers. It works pretty well.
                    • NeoMatrix
                      Senior Tech.
                      • 3514
                      Re: Paper Dust
                      Share a pic of your MacGuyer roller cleaner pad...
                      • Iowatech
                        Not a service manager
                        • 3930
                        Re: Paper Dust
                        Back in the day I ran across Risos that used starch for a similar effect as the offset powder, but luckily that was applied at the entrance of the receiving tray so there were no misfeeds. It did make quite the mess if there were even tiny air currents though, which thanks to the speed of the prints entering the receiving tray was exactly always.
                        • copier_operator
                          • Oct 2016
                          • 9
                          Re: Paper Dust
                          Up to a few weeks ago i was having an bi weekly struggle with dust.
                          Cheap gritty and easily 'fractured' paper will do that - its rarely the end user that gets to decide which paper to use.
                          Took me two years of whining and crunching numbers to convince my superiors to switch to better quality paper.
                          Less downtime due to maintenance, WAY less paperjams, WAY less dust and air pollution in my workplace -and the kicker is - the cost is IDENTICAL to the cheap crap paper i had to use before.
                          Always some guy behind a desk that has never been here - in the workplace - that makes the call on what to buy.
                            • 14406
                            Re: Paper Dust
                            Next time I'm there I will try to remember to snap a pic.
