    • 8155
    #331
    This weeks extreme cold in large parts of North America is caused by global warming directly linked to climate change.
    How climate change is behind this week'''s extreme cold snap | CBC News
    Ever since the bitter winter of 2014, a new winter-weather catchphrase has been making the rounds: polar vortex.
    The polar vortex is nothing new. It's just that it typically it encircles the north pole. However, in recent years, it seems to be meandering southward every so often.
    "This air mass always exists, and it often gets bumped and pushed around. In this case, the jet stream pushed it all the way down to the U.S. Midwest," said CBC meteorologist Johanna Wagstaffe. "Sometimes that air mass can get split, or divided because of the jet stream, so it ends up getting stuck in place."
    That's what happened this week: the jet stream managed to split the descending polar vortex into three.
    The jet stream
    Though it's a relatively new area of study, there's increasing evidence that suggests this phenomenon will happen more often and become more extreme.
    The key lies with the jet stream, a narrow, fast-moving band of air in our upper atmosphere that moves weather patterns around. In the past, the jet stream moved fairly smoothly around the northern hemisphere. But recently, it's developed more pronounced kinks that can bring cold, Arctic air much farther south than in the past, or bring heat from the Gulf of Mexico further north than has been typical.
    And it's linked to the Arctic.
    A recent Intergovernmental Panel on Climate Change report found the Arctic is warming two to three times faster than anywhere else on Earth. This temperature difference upsets the stability of the jet stream.
    And that brings the cold Arctic air southward where it can linger, a result that meteorologists call a blocking pattern.
    "We have seen more of these; we've noticed that trend already, that's proven. And all of our climate models show this trend will continue," Wagstaffe said. "And that doesn't just mean more heat and more drought conditions. It can also mean more of these extreme cold blasts or extreme wet or snowy systems staying in place longer than normal."
    Climate vs. weather
    The important thing to remember when discussing climate change is that climate and weather are two separate entities.
    In fact, at the same time much of Canada is in a deep freeze, other parts of the world are experiencing the opposite.
    "The atmosphere is always trying to balance out its energy," Wagstaffe said. "So right now, on the other side of the globe, parts of northern Europe and northern Russia, they're actually experiencing record-breaking warm temperatures for this time of the year, and really close to the north pole."
    Climate change isn't about what's happening today, but what's happening globally, over time.
    Weather is the state of the atmosphere pertaining to things like wind, moisture, temperature and more that occur on a day-to-day basis. Climate, on the other hand, is the average weather in one place over a long period of time.
    Just because you step outside and the tears caused by bitter wind freeze on your cheeks, doesn't mean that climate change isn't happening.
    • Geo
      • 662
      #332
      So, the earth has been experiencing climate change from it's birth, no denying this...However , I have what should be a simple question to those that believe mankind is responsible for "climate change" . What percentage of the current "climate change" is caused by human activity . Please provide an actual percentage number and references.
        • 14561
        #333
        I guess the opposite question would be "How can someone believe that the amount of crap we throw into the atmosphere has no effect"?
        • Geo
          • 662
          #334
          So you have no answer...Got it..
            • 14561
            #335
            Nope. How about you? Can you answer my question?
            • Geo
              • 662
              #336
              Uhh..Questions are not answered with a question or redirection unless of course one can't or doesn't want to provide an answer...So, after my questions are answered I will entertain your question..Seems fair...
                • 14561
                #337
                Haha. Now that is textbook deflection.
                You let on that your question is an easy one, but I am pretty sure none us here are climatologists.
                My question, on the other hand, should be quite easy for you. It is simply asking how you believe all the pollutants being spewed into the atmosphere can't be affecting anything.
                Are you refusing to answer because you know there must be some effect?
                • Geo
                  • 662
                  #338
                  So you are talking about "deflection" ...You are FUNNY..and a hypocrite....
                    • 14561
                    #339
                    Still refusing to answer. I get it, you really don't have an answer.
                    I answered your question. I don't know any percentages of man vs nature. All I know is that historically, changes in climate took thousands of years, or more. What is happening now is moving along much quicker than that. To me, that means mankind must be causing some of it.
                    Now, tell me how you believe polluting the world over the last several hundred years has no effect.
                      • 8155
                      #340
                      I know it is hard to accept but Climate change and global warming is actually causing the deep cold affecting North America right now.
                      • harleyrider
                        • Oct 2011
                        • 348
                        #341
                        I don't know anything about all that s*** but I do know is has been freaking cold here. -24 without the wind chill. Just sayin LOL.
                        • NeoMatrix
                          Senior Tech.
                          • 3513
                          #342
                          I watched a movie last night called the "Knowing" with Nicolas cage. (Release 2009)
                          The main plot of the movie entailed a super solar flare explosion from the sun the width of our solar system.
                          The earths ozone layer was destroyed in the solar burst. The following morning at dawn saw a band of exploding fire encircle
                          the globe as the sun dawned over the horizon. Terrific earth ground wave explosion CGI effect...
                          The movie ended with off-world entities landing back on a recovered earth and replacing a male and female child at various points on the earth,under the tree of knowledge to signify a return to genesis Adam and Eve scenario....
                          I went to bed thinking that man has too much ignorance an limitation in his own belief system.
                          We place so much importance on filling our escrow accounts (bank ) by destroying the earth, rather than filling our hearts and minds with the things that really matter. We refuse to address the grass roots real social issues, and are quick to place blame at light speed onto others, as we run from our own responsibilities.
                          I felt a tad sad when I said to myself, the ozone destruction scenario would certainly fix mans innate ignorance to the real facts of the universe...
                          I'm not a Nicolas Cage fan.
                          3/5 stars for the movie....
                          • Geo
                            • 662
                            #343
                            Again I asked a simple direct question ,,So, given you don't know the answer why bother responding ? All you have done is redirect/deflect and obfuscate. As for the answer to your question, I already told you , when my question gets answered ,I will answer your ( not about to go off on tangents)...Only seems fair...
                              • 14561
                              #344
                              Haha. You really make me laugh, without even trying I bet. You don't have to worry about answering, I know you won't. PS. I did answer your question. I said I don't know the answer. I don't know the ratio of man made vs natural climate change. Do you know why you refuse to believe that climate change could possibly be caused by us.
                              • Geo
                                • 662
                                #345
                                Lets try this again, my question wasn't specifically directed to you,therefore you had no obligation to respond and no reason to if you didn't have a answer. . However you chose to post a comment that didn't answer my question and added absolutely NOTHING to the discussion, except.... Perhaps you were using your non-answer as a way to redirect the conversation. Sorry , I refuse to entertain or fall for your redirection.
                                As for answering your question, I already told you when I will...
                                As for your last sentence...Why are you putting words in my mouth...????
                                P.S. Glad you find it amusing when someone refuses to accept your non-answer as an answer..
