    • 16331
    #826
    Everything that humans are experiencing today has been witnessed in the past.
    Government researchers have been tracking heat waves for more than 100 years. According to data from the U.S. Climate Change Science Program, which is made available by the Environmental Protection Agency, the annual heat wave index for the contiguous 48 states was substantially higher in the 1930s than at any point in recent years. In some years in the 1930s, it was four times greater or even more.
    Additionally, the National Oceanic and Atmospheric Administration (NOAA) has a large database of daily temperatures that goes back to 1948. NOAA used 1,066 weather stations located across the United States to collect this data.
    According to NOAA, huge swaths of the United States have experienced a significant decrease in abnormally hot days recorded since 1948, especially in the Midwest and northern and eastern Texas.
    Although it’s true that some parts of the United States have seen the number of hotter-than-usual days increase over the past 70 years — including in California and the New York metropolitan area, both of which happen to be areas where a large number of media outlets are located — most weather stations have shown no meaningful changes or even declines.
    Meteorologist Anthony Watts, who works with me as a senior fellow at The Heartland Institute, analyzed NOAA’s data in detail and found that 81% of the weather stations used in NOAA’s database reported that since 1948 there has been "either a decrease or no change in the number of unusually hot days."
    If the available data so clearly reveal that there is no heat-wave crisis, why are media outlets suggesting the opposite is true? The answer is sloppy, irresponsible media reporting, combined with cherry-picked data.
    Anyone who wants to show a long-term warming or cooling trend can do so by selectively choosing starting and ending points in datasets that will provide the answer you’re looking for.
    For instance, if you start your examination of historic temperatures with figures collected in the 1970s, when temperatures were unusually low compared to the rest of the century, then current temperatures look abnormally high.
    If you start around 2010, then temperatures over the past decade appear to have dipped below "normal" and are only now recovering.
    When many media outlets and left-wing politicians talk about climate change data, they almost always selectively choose a range that offers an incomplete picture of the larger available dataset. This makes it appear as though today’s temperatures are "historic" when they are actually well within normal historical ranges.
    Another problem is that media outlets have been using temperature forecasts in their news reports as if those figures were actual temperature data. A forecast is, by definition, a guess, and some alarmist analysts have recently made a bad habit of incorrectly predicting insanely high temperatures that never come to fruition.
    For example, the Telegraph, one of the largest papers in the United Kingdom, published an article on July 18 in which the author claimed, "The European Space Agency said thermometers could tip 48C in Sardinia and Sicily, while the temperatures in Rome and Madrid could both reach the mid to high-40Cs. In drought-stricken Spain, temperatures were set to reach highs of 44C in Catalonia."
    Heat waves happen every year, but this isn’t evidence that Americans are facing a global warming crisis. When heat-wave data are put into their proper historical context, it’s clear that everything humans are experiencing today has been witnessed in the past.
    The ugly truth behind climate alarmism is that much of it is driven by a radical ideological agenda that is seeking to transform the global economy and American society, not by science. The best way to fight back against it is to use cold, hard facts. And those facts plainly show that there is no reason to panic about our ever-changing climate.
      • 8157
      #827
      This month is the planet’s hottest on record by far – and hottest in around 120,000 years, scientists say
      As vast swaths of three continents bake under blistering temperatures and the oceans heat to unprecedented levels, scientists from two global climate authorities are reporting before July has even ended that this month will be the planet’s hottest on record by far.
      The heat in July has already been so extreme that it is “virtually certain” this month will break records “by a significant margin,” the European Union’s Copernicus Climate Change Service and the World Meteorological Organization said in a report published Thursday.
      We have just lived through the hottest three-week-period on record – and almost certainly in more than a hundred thousand years.
      Typically these records, which track the average air temperature across the entire world, are broken by hundredths of a degree. But the temperature for the first 23 days of July averaged 16.95 degrees Celsius (62.51 Fahrenheit), well above the previous record of 16.63 degrees Celsius (61.93 Fahrenheit) set in July 2019, according to the report.
      The data used to track these records goes back to 1940, but many scientists – including those at Copernicus – say it’s almost certain that these temperatures are the warmest the planet has seen in 120,000 years, given what we know from millennia of climate data extracted from tree rings, coral reefs and deep sea sediment cores.
      “These are the hottest temperatures in human history,” said Samantha Burgess, deputy director at Copernicus.
      It all adds up to a blistering Northern Hemisphere summer – potentially an unprecedented one. “The odds are certainly in a favor of a record-breaking summer,” said Carlo Buontempo, the director of Copernicus, although he cautioned that it’s too early to state that with confidence.
      The human toll of the heat is stark. As temperatures have risen above 120 degrees Fahrenheit (50 degrees Celsius) in parts of the US, heat-related deaths have mounted and people are suffering life-threatening burns from falling onto scorching hot ground.
      In the Mediterranean, more than 40 people have died as wildfires rage across the region, fueled by high temperatures. In Asia, prolonged, intense heat waves are claiming lives and threatening food security.
      Human-caused climate change is the main driver of this extraordinary heat, Burgess said. “The global air temperature is directly proportional to the concentration of greenhouse gases in the atmosphere.”
      A recent study found that climate change played an “absolutely overwhelming” role in the heat waves in the US, China and southern Europe this summer.
        • 29977
        #828
          • 881
          #829
          [QUOTE=SalesServiceGuy;2428291]
          These claims are just why its hard to believe in "man made " climate change . Just say anything crazy , someone will believe it .
            • 29977
            #830
            [QUOTE=BBM;2429101]
            Yep like Mexico will pay for the Wall
            Yep like the election was stolen
            Yep like one day it will just disappear
            Crazy isn't it
              • 37395
              #831
              This is why no one speaks up and out against the greatest political fraud of the modern age. The immense power and machinery of the left will destroy you.
              Nobel Prize winner canceled by IMF after denouncing 'climate change' alarmism - LifeSite
                • 8157
                #832
                Phoenix’s record heat is killing off cactuses
                At a botanical garden in Phoenix some cactuses can’t take the heat.
                Record-high temperatures in Arizona, combined with a lack of seasonal monsoons, have caused saguaro cactuses at the Desert Botanical Garden to become “highly stressed,” according to Chief Science Officer Kimberlie McCue. She said a saguaro can appear “fairly normal” or feel somewhat squishy before it suddenly collapses and reveals it has been rotting from the inside out due to heat-related stress.
                Every February, the Desert Botanical Garden takes inventory of its saguaro cactuses and assesses each one’s condition. McCue said since 2020, when record temperatures caused stress in many of the saguaros, she and her team have seen more of the garden’s cactuses die. Present-day heat records are sending some of those previously affected cactuses over the edge, causing them to lose limbs and even collapse.
                Cactuses carry out essential functions at night. That’s when they open their stomata, or pores, and carry out a gas exchange in which they take in the carbon dioxide they use to photosynthesize during the day. But because nights in Phoenix have experienced record-high heat, McCue said this suffocates and stresses out the saguaros, which dehydrates them and makes them more susceptible to infections and insects.
                Saguaros are “beautifully adapted to heat and aridity, but they have their limits,” McCue said.
                Phoenix is one of nine US cities where at least 1 million people live in neighborhoods that reach eight degrees higher than surrounding areas, a Climate Central analysis showed. But down in Tucson, where temperatures are slightly lower but still surpassing 100 degrees, plant admirers like Erik Rakestraw aren’t seeing the same distress in local saguaros. He attributes the perseverance of Tucson’s cactuses to the lack of a “heat island” effect that Phoenix is experiencing.
                The biggest threat to saguaros is that as temperatures heat up over time, new generations of the cactus species will struggle to grow at all.
                  • 37395
                  #833
                  Energy Industry Fears White House Will Declare COVID-Like '''Climate Emergency''' | The Epoch Times
                    • 29977
                    #834
                    COVID-19 lockdowns happened under the failed TRUMP Administration that a Fact Jack
                    Amazing you guys think it's fake heat
                      • 37395
                      #835
                      How To Create Conspiracy Theories - VDH’s Blade of Perseus
                        • 29977
                        #836
                        Yep your a Sucker
                          • 14563
                          #837
                          "The researchers found that overall, people were motivated to believe in conspiracy theories by a need to understand and feel safe in their environment and a need to feel like the community they identify with is superior to others."
                          Why some people are willing to believe conspiracy theories
                            Climate Change Theory up in Smoke as Drone Video Shows Man Sparking Wildfire in Italy
                              • 8157
                              #839
                              Arizona’s extreme heat is killing honeybees and melting their homes
                              As deadly, unrelenting heat scorches Arizona, some entomologists are growing concerned about the increasing number of dead honeybees – a species vital to our ecosystem, especially food production.
                              Temperatures in Phoenix hit 110-plus degrees for a record-breaking 31 consecutive days from June 30 to July 30, part of what was the hottest month on record for any US city.
                              This unprecedented heat has bee experts across Arizona sounding the alarm bell.
                              “It’s a very major concern,” Shaku Nair, an entomologist with the University of Arizona, told CNN, “Honeybees can forage up to 113 degrees. As of July, we’ve had many days over 113 degrees, so bees are taking a bad hit right now.”
                              Phoenix-based beekeeper Cricket Aldridge, who now spends many of her days saving bees from the heat, told CNN “bees’ homes are being melted” and “other bee colonies are attacking honeybee colonies due to food scarcity.”
                              According to Dan Winter, President of the American Beekeeping Federation, it requires very extreme heat and no water for beehives to melt because they use evaporation to cool down.
                              Arizona honeybees battle the relentless heat by using water and their wings to cool down the hive, Nair explained, and to keep the brood alive, they must maintain a hive temperature between 92 and 104 degrees. However, with temperatures so high, there’s only so much they can do.
                              “We are seeing dead bees around hives,” Nair says, “That is because of the heat – it’s too hot in the hives and bees won’t let[other bees] back in.”
                              When honeybees leave the hive to forage for food, options are scarce, according to Nair. Weeks of nonstop heat in Phoenix have wilted flowers and killed saguaro cactuses, important food sources for honeybees.
                              Nair warns that humans could see the impacts of more dead honeybees for many years to come, and a drop in pollination could lead to a disruption in food production. Foods like melons, citrus fruits, zucchini, coffee and chocolate all depend on bees.
                              Unfortunately, heat is just another added stress on honeybee populations that are already in danger. Last year, beekeepers in the US lost an estimated 48% of their managed honeybee colonies, according to Beeinformed.org.
                              Winter said bee populations are on the decline due to rising threats from pests and threats to their nutrition and habitat. Winter told CNN that humans have put bee habitats in jeopardy with monoculture, which “is a big problem because it doesn’t leave a lot of nutrition for bees.”
                              Bee experts have a message for regions dealing with extreme heat – put out water for bees and maintain more native plant species. “Bees usually do well as long as they have water,” Winter said.
                                Phoenix has traditionally been one of the hottest places on the planet, so no calls for alarm.
