My new handy tool
  • fixthecopier
    ALIEN OVERLORD
    • 4713
    My new handy tool
    I had a couple of machines lately, that had a dirty hard to get to photocell causing an issue. In both cases I went to my truck, retrieved a drinking straw and used it to blow out the photocell with out removing more screws. I then found in the sporting goods section at Wally World, a set of stainless steel drinking straws for $3. Now my latest handy tool in my bag. Also used one to get lube to a bearing without getting it everywhere else.
  • copyman
    Owner / Technician
    • Sep 2005
    • 4700
    Re: My new handy tool
    Not sure I understand, did you use the straw to extend the thin straw that comes with cans of air?
      • 23008
      How does the oil taste? =^..^=
      • KenB
        Geek Extraordinaire
        • Dec 2007
        • 3944
        In a pinch, you could always get temporary replacements at your local McDonalds.
          Originally posted by KenB
          In a pinch, you could always get temporary replacements at you local McDonalds.
          and they are FREE! sos if you lose one it really doesn't matter!
          Best accessory I bought was a Vacuum Kit...
          45 deg thin tube
          5" str8 extention
          3" str8 ext
          reducer coupler
          thin tube w/ brush tip
          8.99usd @ Uline
          • tsbservice
            Field tech
            • 8013
            Like this?
            Industrial Peanut Vacuum Kit H-1610 - Uline
            Cool thread.
            • fixthecopier
              ALIEN OVERLORD
              • 4713
              Can of air? Look who has money to burn. My shop quit buying that stuff 18 years ago.
              Best recent purchase was a fold up hand cart from Harbor Freight. $25 and for $10 more they put a 2 year replacement on it, no matter what I do to it. I take that as a challenge.
                • 23008
                I'll jump in: I like the UpCart. It took me 5 years to break the first one. I'm 2 years into the second one. Pay the extra for the cast aluminum front legs. The ones I made cost me another $50.
                • copyman
                  Owner / Technician
                  • Sep 2005
                  • 4700
                  Now I understand. And it can be expensive if buying canned air for the whole service dept in big company.
                  Cans of air prob one of my top 5 used items in bag. I'm self employed and write cost off as if a tool. As far as I'm concerned a very valuable tool. Buy it by the case and get a decent break in cost. Using Uline cans currently and is ok. I miss Densigraphix canned air, best pressure ever, turn can upside down and could freeze a bug in mid-flight 6 feet away
                  • ZOOTECH
                    Senior member of CRS
                    • 3375
                    Be careful of the canned air, some are flamable; I was cleaning a machine with the spray and vacuumeing at the same time when a loud 'bang' interrupted a quite morning.
                    • copyman
                      Owner / Technician
                      • Sep 2005
                      • 4700
                      [QUOTE=ZOOTECH;1165079]Be careful of the canned air, some are flamable; I was cleaning a machine with the spray and vacuumeing at the same time when a loud 'bang' interrupted a quite morning.[/QUOTE
                      Thanks for the heads up. Never thought of that. I have seen toner blow up a regular hoover handheld vacuum years ago. And it's not pretty if filter was really full.
                      Or like a rookie tech at last company I worked for. He left 2 new cans of "compressed" air sitting on dash of company car, with outside temp of 90+ degrees! Blew winshield clean out, tore healiner to shreds !!! Lasted 2 more weeks with company.
                        • 14725
                        I think I will take my chances with canned air rather than using a straw to blow into a piece of electronic equipment
                        • allan
                          RTFM!!
                          • 5462
                          Just add straw...
                          My new favorite toy must be the hot air tip for my gas soldering iron.
                          Useful to reshape plastic.
                          Whatever
                            • 23008
                            Google: Giottos Air Rocket.
                            Somebody here recommended it to me and I haven't used canned air since. Using compressed air you're just re-distributing the dirt anyway ... right into another sensor or a laser or something even more sensative.
                            • Bix
                              • Apr 2018
                              • 1421
                              Originally posted by allan
                              [ATTACH=CONFIG]44527[/ATTACH]
                              Just add straw...
                              I never thought about it, interesting idea. it is the same that I use in reflex cameras
