canon hard drives
  • tonerhead
    • Sep 2009
    • 582
    canon hard drives
    I am trying to use a canon hard drive in a computer. Unable to read/write to the hard drive as it needs a password. I am thinking Canon uses TPM to lock down their hard drives to the copier.
    I have tried gparted, dban, and everything else, no sucess. Has anyone gotten past this password lockout?
    Ricoh's are easy, just take the hdd, just do low level format and resuse. Not so easy with a canon.
    I've proved mathematics wrong. 1 + 1 doesn't always equal 2.........
    Especially when it comes to sex
    • 37062
    Re: canon hard drives
    If Windows disk management won't allow access, try a low level disk format utility or a partitioning software such as MiniTool Partition Wizard. Try the free home edition first. It also comes in handy when you have an older machine that uses smaller USB thumb drives.
      • 2621
      Personally, I wouldn't use Windows for this job, since most copiers use a derivative of Linux.
      Command line error messages can be searched with google, what do you get if you
      sudo fdisk -l
      also, what happens if you try and mount it, obviously /dev/sdb and /mnt/media need to be changed to your specifics.
      sudo mount /dev/sdb1 /mnt/media
      • tonerhead
        • Sep 2009
        • 582
        Thanks for the suggestions. Slim.... your suggested program did not work. Skynet.... I have tried mounting in linux, no worky.
        So far I have tried low level format, gparted, command prompt, terminal, etc. I have tried to over write with Debian installer nothing works. During training once I asked the Canon trainer about this. He said nothing you can do to recover the disk for other uses. I am thinking he was correct.
        If nothing else they might make excellent 50 yard targets on the shooting range.
        • Michael
          • 158
          My profile is not working at the moment. The profile you see is not mine. Board redirects to a wrong userprofile. So you CAN´T REACH ME over the profile via SEND PRIVATE MESSAGE and even not over regular Email too
          You only can contact me if you click my name on a post and select PRIVATE MESSAGE straight from there.
          • tsbservice
            Field tech
            • 7943
            Canon U.S.A., Inc. | Hard Drive Solutions
            I guess You may try HDD format featured in machines.
              • 2621
              Now you mention it I recall a bit about the training and the tpm module, it encrypts the hard drive to such an extent its unusable.
              • tonerhead
                • Sep 2009
                • 582
                Here is the hitch. You can't mount a canon hdd in linux. Windows mmc actually sees the hard drive but it shows no media in the hdd. We even have a stand alone hdd eraser. Even that will not clear the tpm password. Whether it be windows or whatever there is always a read/write error to the hard drive because the tpm password is encoded into an eprom on the hdd from the copier. I put the sucker into a computer, the computer boots bios and the first thing askes for the hdd password.
                Have you ever tried badblocks on a canon hdd? I would be curious to see if it works for you.
                  • 37062
                  And therein is the bugaboo. According to Asus "The HDD password protects all data stored on the hard disk, keeping the data safe from being read or overwritten by unauthorized users. The TPM creates cryptograhic keys and encrypts them so that they can only be decrypted by that particular TPM. This allows the hard disk drive to be tied to a particular device which has TPM embedded."
                    • 8121
                    Which model Canon did the drive come from?
                    • tonerhead
                      • Sep 2009
                      • 582
                      C250. Doesn't matter though, I've tried others with same result.
                      • Michael
                        • 158
                        4 Unlock And Recover Hard Drive Password With Hard Disk Password Removal Tool
                          • 37062
                          One problem with that link. It does not cover TPM encrypted drives. They use a triple level access, password, encryption key and encrypted handshake with the original hardware it was installed in.
                          • tonerhead
                            • Sep 2009
                            • 582
                            Totally agree with Slim. I have cleaned several hdd's in the past with dban, lots of times even a simple windows format gets them usable. The problem with these Canon hdd's are read/write is cancelled due to the TPM. Gparted knows the disk is there, but can't read/write, same with all of the others. They all know the disk is there but can't do anything with it because of the TPM coding in the hdd bios.
                            • Michael
                              • 158
                              maybe this:
                              How to remove password from your Hard Disk ? – GreeksCrowd
                              or this:
                              ATA Secure Erase - ata WikiWhat is a TPM, and Why Does Windows Need One For Disk Encryption?
