White Out
  • treed889
    • Mar 2010
    • 24
    [WTF] White Out
    So I'm still a newbie for the most part (less than 5 months on the job) workin on copiers but one thing I have never figured out is why does white out leave dark streaks when you use the doc feeder? The light compares the image you scan to a white background judging the color so when it sees a constant white spot should it not register it as a white or blank spot on the page??? just something that puzzles me and thought would get some good conversation.
    oh yeah and TGIF!!! have a good one
  • vincent64
    • 382
    Welcome to the ranks, if you make it a year, you just may make it, next time you have some w/o on a scan glass, SPF glass, or what ever you call it, take the glass out, flip it over and take a look from the machine point of view, it aint white, and most time is has come off a document, may have some of the ink they were whiting out mixed in there as well.
      • 23006
      Yep. After paper has rubbed across that whiteout a few thousand times, it will look somewhere between gray & black.
      As an experiment, take some whiteout and a piece of paper and smear it around with your finger. It won't be white. =^..^=
      • ToshibaTech
        • Apr 2007
        • 580
        These things are alien technology. It's the only explanation I have come up with for anything over the years.
        I will not give you service manuals or firmware.
        • pacman
          I can turn a screw...
          • 318
          I KNEW IT!!!!!!
          • gwaddle
            • May 2009
            • 782
            I thought they were just magic. That's what I tell the customers.
            I know I should be ashamed of myself. Strangely though, I am not.
            • treed889
              • Mar 2010
              • 24
              haha thanks guys i'll have to check that next time instead of just scraping it off.
              • ZOOTECH
                Senior member of CRS
                • 3375
                When I can't explain a fix, I tell the customer it's either AM or FM (another miracle or frickin' magic).
                • treed889
                  • Mar 2010
                  • 24
                  haha never thought of AM and FM like that, thats simple and clever.
                  • 10871087
                    • Jan 2005
                    • 1062
                    Been around a long time, never heard that one before.
                    • ZOOTECH
                      • 3375
                      My original (pat on the back) from 10-15 years ago.
                      • prntrfxr
                        • 1622
                        I agree with Blackcat. I believe that whiteout, although white is not reflective. Light is absorbed instead of reflected, and therefore appears as a black line. It hasn't been proven though, so it is a good question. Wonder if we could get a scientist to add the definitive answer to the Wiki Whiteout article?
                        Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways - Coke in one hand - chocolate in the other - body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!".
                        • mikadonovan
                          • May 2008
                          • 2931
                          I think that it uses the white strip to set a reference point as 0, so anything even a little different, including a different shade of white will register a value other than 0 and show up as print.
                          NEVER ASSUME ANYTHING
