This generally gets you a good long run before any callbacks, if I can fully load up a machine before I leave I will. I had a client that would let it run down and put one bloody ream in at a time, resulting in jamming because the end users were always in a hurry 'cause they had to stop for 20 seconds to put paper in it. After service I'd load it to capacity - 6 reams in tandem, 7 reams in LCT, plus one ream each trays 2 and three for 7500 sheets total and could just about guarantee no jams for 10k.
Test Copies... What is your personal best.
"You can't trust your eyes, if your mind is out of focus" --Comment
OMD-227
Ha!
Imagine just sitting there watching the machine do 300K as a 'test run'.
The client walks up and wants to use the machine, and you politely say with a straight face.......
'sorry, just running off 600 reams of paper as a test. Can you come back later'.
That would go down beautifully.Comment
Ha!
"It's just the standard maintenance test. Come back in ... um, a few days."
=^..^=If you'd like a serious answer to your request:
A few years back I had a customer claiming constant jamming. I went out machine ran perfect. Day 2 same thing so I filled and emptied all trays. Couple days went by the mystery jam is back I go out machine runs fine for me again. By this time I've run over 5,000 test copies on the machine. A few more days go by and the problem comes back. This time the owner is demanding a new machine so I meet him first thiing in the morning at the office. When I arrived the machine was showing a jam when me and the owner walked over to the machine. That is when I noticed the 8:30 am sun was coming thru the office's front window and hitting the machine strait on at a low angle. I closed the blind and the jam went away. I opened the blind and the jam came back. Problem solved. By 8:45 the sun had moved enough that it was no longer hitting the machine and by 9:00 the sun was nowhere near the machine. Go figure.Comment
A few years back I had a customer claiming constant jamming. I went out machine ran perfect. Day 2 same thing so I filled and emptied all trays. Couple days went by the mystery jam is back I go out machine runs fine for me again. By this time I've run over 5,000 test copies on the machine. A few more days go by and the problem comes back. This time the owner is demanding a new machine so I meet him first thiing in the morning at the office. When I arrived the machine was showing a jam when me and the owner walked over to the machine. That is when I noticed the 8:30 am sun was coming thru the office's front window and hitting the machine strait on at a low angle. I closed the blind and the jam went away. I opened the blind and the jam came back. Problem solved. By 8:45 the sun had moved enough that it was no longer hitting the machine and by 9:00 the sun was nowhere near the machine. Go figure.If you'd like a serious answer to your request:
I do pretty much what the rest of you do.
What annoys me is the bitching and complaining I get if I use a couple thousand sheets "to prove" it is not the machine.
Most of the time I had noted, the problem is usually user introduced as some here say. The most common is in the large capacity drawers where several reams can be stacked. Usually the top few and bottom few pages are messed up from careless loading. The majority of these, a half dozen sheets pushed towards the feed mechanism so that when the stack reaches the feed unit within a hundred pages of those offset pages, the feeder can no longer properly feed paper through."Many years ago I chased a woman for almost two years, only to discover that her tastes were exactly like mine: we both were crazy about girls."
---Groucho Marx
---Groucho Marx
Yes, the sun is our indeed our friend, by "messing us like this", it is actually warning us not to expose the machine to its direct path. The manufacturers themselves always tells us not to install the machines in an area directly exposed to the sunlight. the reasons are simple enough:
The sun itself is the largest natural source of ELECTROMAGNETIC ENERGY known to man. SECONDLY, The photocopying machines have in them numerous PHOTO-INTERRUPTORS (sensors), photocells, etc all whose functions are all based on the actions of electromagnetic energies. Although these EM energies are internally generated ( artificially), by the machines (& controlled) they have exactly the same property (characteristics) as produced by the sun in nature. Therefore direct exposure of these equipment to the sun's rays affects the operations of the photosensitive components in the copiers.
Remember that, we are really dealing with MATTER & ENERGY which, on their own, exists freely in nature. In designing the physical systems (or machines), the Engineers simply do MODELING, which really is a Mathematical ( CALCULUS) description of the physical system, Obtained ,by Application of the appropriate LAWS OF NATURE! for example "Energy is neither created nor destroyed....". Therefore, 'our friend' the sun by causing our machines to' paper jam', is simply telling us to move it away from its path, in accordance with the natural laws of existing in 'Harmony' with one another.Comment
Remember that, we are really dealing with MATTER & ENERGY which, on their own, exists freely in nature. In designing the physical systems (or machines), the Engineers simply do MODELING, which really is a Mathematical ( CALCULUS) description of the physical system, Obtained ,by Application of the appropriate LAWS OF NATURE! for example "Energy is neither created nor destroyed....". Therefore, 'our friend' the sun by causing our machines to' paper jam', is simply telling us to move it away from its path, in accordance with the natural laws of existing in 'Harmony' with one another.I know I should be ashamed of myself. Strangely though, I am not.Comment
I have a school in a indian reserve with a ARM550. There is always a shit load of jams on this puppy but 90% of them come from tray 1 or just after tray 1. Problem is, they don't load the LCC up with 2k sheets. The machine is always empty. The teacher comes in with 100-200 sheets of paper that they have clutched in their hand as they walk down the hall, open the LCC and toss it in. Jam jam jam jam. That LCC is ment to be opened once every 2000 pages, not have 100 pages thrown in, run 100 pages then take the paper out and leave. 3.2 million later and it's getting pretty fracked.Evil will always triumph because good is dumb.Comment
I was being facetious."Many years ago I chased a woman for almost two years, only to discover that her tastes were exactly like mine: we both were crazy about girls."
---Groucho Marx
It's not that hard to load 100 pages twice into the bypass to make 200 copies. Few teachers make that many consecutively. =^..^=If you'd like a serious answer to your request:
A lot of schools do this. I've had to insist that if they're going to make the teachers bring their own paper for every copy, it must be fed through the bypass. The trays just get slammed to death by 20 copies, open drawer, close drawer, open drawer, insert 50 sheets, make 20 copies, open drawer, close drawer, open drawer, ...
The people who work at this place probably don't work there because they love working in native reserves but it's the best they could get!Evil will always triumph because good is dumb.Comment
