home office copier
  • cam81572
    • Aug 2025
    home office copier
    Home office - copier limited space
    I have a remote office location in my home. My home office has a Kyocera KM-2560. I am looking for a similar copier.
    I have limited space 27 x 27.
    I am looking for a quality scannerwith the copier. I am looking for quality with small file size. I have a Fujitsu 6130 and the quality and file size is not good. The Kyocera gives good quality and small file size.
    Quoted
    Copystar - 255 multi- functional . My boss is asking if this is a good brand. I was told it had Kyocera Technology. Does anyone know how the scanner quality and file size it?
    Konica Minolta bizhub 25 - Good? Scanner ??
    Sharp MX-B402SC- Good? Scanner?
    Which is better? They are basically the same based on the specs.
    Thanks for any help!!
  • Zackuth
    • Aug 2009
    • 448
    Re: home office copier
    Have you looked into desktop models? While they will lack in features, they do save in space. I don't have any experience in the Konica Minolta or Sharp machines, but we do have about 10 of the 255/305 (B/W) in the field. With the exception of a board failure, which has been addressed and corrected, we have had no issues with the machines.
    If at first you don't succeed, redefine success
      • 23009
      What's wrong with the KM-2560? For a small machine it's reliable and has a lot of features built in. =^..^=
      • JR2ALTA
        • Feb 2010
        • 2033
        Bizhub 25 is decent. Pretty much made for one man operations. It scans but don't expect it to feed it stacks of paper all day...been there done that.
        But with some desktop machines, you need to deal with certain problems that aren't correctable. Maybe the fuser curls the paper, maybe the cassettes skew the image a little or maybe the simple document feeder can't handle long runs without jams.
        I ask the same question as BC, what happened to the 2560? It's professional grade..and you already own it.
        • ddude
          General Troublemaker
          • 473
          I don't know if you can compare a Copystar to a Kyocera........
          2000 mockingbirds = 2 kilomockingbirds
          • JR2ALTA
            • Feb 2010
            • 2033
            ddude is kidding of course, because Copystar is a plastic nametag glued to Kyocera machines. Exactly the same.
