Any home remedies to discourage the kittens from chewing up cords?
    • 22999
    Re: Any home remedies to discourage the kittens from chewing up cords?
    So far, so good with Wiremold raceway, and the jalapena water. I noticed after an hour of coating the wires my nasal passages started to tingle. The kittens don't sit behind the desk any more. I'm hoping this is the end of this thread. =^..^=
    • Venom
      Technical/IT Support
      • Nov 2009
      • 765
      You need to mark your territory so they know not to go there. You need to pee around the parameter of the room for a week.
      IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
      • neergish
        • 177
        "See if you can rent a spring hook and a phillips screwdriver it will make your life that much easier..."
        • HenryT2
          • 962
          #19
          Sorry 'bout the antifreeze thing .
          Glad you may have a CURE ... if that does not work....you could get about 20 or 30 mice and let them loose in the house. The cats will be too busy chasing the mice to nibble on the cables.
          "The Serenity Prayer" . . .
          God grant me the serenity to accept stupid people , the courage to not waste my time and energy on them , and the wisdom to know that I cannot fix STUPID .
          • Jules Winfield
            • Jul 2009
            • 821
            #20
            Yeah, but then you'd have mice chewing on the cables, which is probably worse...
            But I'm trying, Ringo. I'm trying real hard... to be the Shepherd.
            • HenryT2
              • 962
              #21
              AW MAN !!!! Well !!! ...the cats should keep the mice so busy they will not have time to chew on the cables ....
              • Jules Winfield
                • Jul 2009
                • 821
                #22
                Of course, I'm pretty sure anti-freeze works on both cats and mice...
                • kyrenecopy
                  • Apr 2012
                  • 205
                  #23
                  OMG! This is sooooo easy, GET RID OF THE CATS! Duh...............
                  Testing 1-2-3, testing, testing. Is this thing on?
                  • DWise
                    • 895
                    #24
                    I don't think that is a viable resolution for Blackcat...
                    Do for one what you wished you could do for everyone. - Andy Stanley
                    • mikadonovan
                      • May 2008
                      • 2931
                      #25
                      Originally posted by neergish
                      May not help on the network cables, but VERY inventive. No cats harmed in that video.
                      NEVER ASSUME ANYTHING
                      • mikadonovan
                        • May 2008
                        • 2931
                        #26
                        My cats hate the smell of mink oil (boot waterproofer).
                          • 22999
                          #27
                          Very satisfying! I like the device, complete with lighting, video gear, and high pressure water spray.
                          It's going to take a while to coat all the susceptible wiring, but it's an unqualified success. They won't even sit near it. I'm weeping tears of joy right now, or perhaps it's the jalapena ...
