Touch Panels once again.....
  • Hansoon
    • Sep 2007
    • 3401
    Not responding touch panels often can be repaired as long as the problem lays in the connection of the flat ribbon cable.
    However, many customers irritated by the non responsive Touch Function use excessive force and sharp objects such as pens to operate the panels. Furthermore some of our colleagues try to revive not responding Touch Panels by putting them in an oven at high temperatures. This all results in invisible damage to the thin plastic foil on top of the glass pane making a repair impossible.
    For this reason we intend to supply in the future brand new aftermarket Touch Panels in such cases where repair is not possible anymore.
    To offer a complete assortment for as many models we like to know once again which models from what manufacturers are suffering from not responding Touch Panels.
    Kindly post here the manufacturers name and model knowing to have been affected.
    Many thanks in advance
    Hans
    touchpanel[at]rex-technika.com
    • 23010
    Re: Touch Panels once again.....
    It must be that time of the year again. Within the last week I've replaced:
    (2) Copystar VoyagerE (CS-C2525E, CS-C3225E, CS-C3232E, CS-C4035E)
    (1) Copystar Stratos (CS-2560, CS-3060)
    (1) Copystar Stratos (CS-2540, CS-3040)
    (1) Konica Minolta bizhub 350
    It comes around twice a year, and I'll have to change a dozen or so touch panels (tablets).
    Sometimes cleaning the grit out from around the cover edges will help. I'll try that first, and re-aligning the screen, but lately the majority have been parts replacement. =^..^=
    • Hansoon
      • Sep 2007
      • 3401
      Thanks Cat. With Bizhub 350 you mean the color or BW models?
      Are they all the same type or are they different in size and location of the ribbon cable?
      Hans
      • Eric1968
        • 2458
        Ricoh MP C2000/C2500/C3000/C2800/C3300/C4000/C5000, MP2510/3010/3025/3030/2250/3350.
          • 23010
          Hans
          Sorry, it was a C350 (color). The Copystar tablets all have the ribbon cable in approximately the same location, but the size of the tablet is different on each group of machines.
          Last year it was Canon iR4570's the used tablets.
          • Hansoon
            • Sep 2007
            • 3401
            Dank je wel Eric.
            Zijn ze allemaal hetzelfde type of hebben ze verschillende afmetingen?
            Bedankt alvast.
            Hans
            • Hansoon
              • Sep 2007
              • 3401
              Could be indeed. If high humidity is present moisture deteriorates the compound between the ribbon cable and traces on the glass pane.
              Hans
              • Eric1968
                • 2458
                Dank je wel Eric.
                Bedankt alvast.
                Hans
                Volgens mij zijn ze allemaal hetzelfde, alleen hebben ze allemaal verschillende artikelnummers.
                Eric
                • Hansoon
                  • Sep 2007
                  • 3401
                  Is het voor jouw bezwaarlijk Eric mij die part# van de verschillende panels te geven?
                  Vriendelijke groet
                  Hans
                    • 23010
                    Hans
                    I read that in a bulletin, somewhere. I've got a few working for a week or more just by pressing the ribbon to the tablet. It never seems to last for more than a few days or a week though. =^..^=
                    • Hansoon
                      • Sep 2007
                      • 3401
                      Cat, would it be a big trouble for you getting me the part#'s please?
                      Hans
                      • Eric1968
                        • 2458
                        Vriendelijke groet
                        Hans
                        Is goed, ga straks ff kijken.
                        • Eric1968
                          • 2458
                          Ricoh MP C2000/C2500/C3000/C3500/C4500 : B223 9900
                          Ricoh MP C2800/C3300/C4000/C5000 : D029 9900
                          Ricoh MP 2510/3010/2550/3350 : H310 9900
                          Ricoh MP 2250/3350 : D009 1488
                          Eric
                          • Hansoon
                            • Sep 2007
                            • 3401
                            Hartelijk bedank Eric.
                            Groetjes naar Rotterdam.
                            Hans
                            • eddie110171
                              • May 2012
                              • 133
                              CS/KM 3050 4050 5050
