Grease for moving parts
  • BHRLC
    • Nov 2013
    • 77
    Need some all or multi-purpose grease for copiers and printers...
    Will not be servicing Xerox's.
    Could someone point me into the right direction to purchase a few tubes / jars?
    Specialty grease advice is appreciated too, esp. for copiers - what to get?
    Moly, graphite, etc...
    I've already been to Walmart and Autozone; Couldn't really find anything useful but
    then again, I'm in a small town.
  • Tonerbomb
    AutoMajical Resolutionist
    • Feb 2005
    • 2589
    Re: Grease for moving parts
    Superlube grease and oil. Good to high temps. I use it for fuser drives. Available from Harbor Freight, sometimes Menards. It's the only lube I carry.
    Mystic Crystal Revelations
    • Ctl-Alt-Del
      • Jul 2006
      • 430
      It is rare that anything on a copier or printer would need anything that and average person would call "Grease". Cleaning will fix many of your problems, thoroughly cleaning will fix most of your problems and if you must use a lube I would recommend a pen style oiler with some sort of synthetic oil.
      Superlube is the way to go, works in all temp ranges and it doesn't collect dust like most non-synthetics do, and just like T-Bomb it's been the only thing in my bag for 15 years. Did I mention that cleaning will fix most of your noise issues?
      • Iowatech
        Not a service manager
        • 3930
        High temperature rated Krytox from DuPont works pretty good for almost everything, as long as you don't have to repack Riso air pumps.
        I don't know if it is available anymore, but I used Slick 50 One Lube for quite a while with good results.
          • 22929
          These are the "greases" that I still carry, but honestly don't use very frequently any more:
          White Lithium Grease: for plastic-on-plastic or plastic-on-metal applications
          IBM 23: for greaseable spring clutches
          Molycote HP-500: for high temp applications, like Sharp creaky fusers
          The original Marvel Mystery Oil (made with real seal oil): for Canon plastic wrap feed clutches (NP-2020)
          Straight Weight W30 Motor Oil: for scanner rails (stays where you put it)
          3-In-1 Machine Oil or Triflow: for bronze oil impregnated bushings
          Fuser Oil: to extend the life of fuser cleaning felts and to keep thermistors clean
          Many of these are now unnecessary, and when they're consumed will not be refilled. =^..^=
          • BHRLC
            • Nov 2013
            • 77
            Great advice guys, thanks again
