Which copier was the biggest piece of crap ever?
Re: Which copier was the biggest piece of crap ever?
I HATED the days right after the merger when nobody had a clue who was in charge and what the combination was going to put out next.Comment
Understood, I was on the other side of the fence, Legacy Konica and when the service modes and codes started making sense to nobody, the complaints started flying. And yes, the 7155 was a weird box. Seemed to dump toner and could not keep clean. Feed units were easy to service but required too much service. The prior machines were much stronger (except for the 7055 7065) Still, compared to some of the current machines, they were not as bad as they got to be.
The only thing worse than one POS is two POSs.Comment
By far the machine that I hate to work on the most is the xerox 9201 colorqube. Every call takes up half your day purging print heads and masking jets. The 30 min warm up time is ridicules. The only positive thing about them is they rarely jam.Comment
If my memory serves me right, there was a thread that asked the opposite question. something like the best copier you worked on, i tried to find it but could not at the moment. Anyway the consensus seemed to be the kyocera falcon2 series. km-3035.THE ONLY THING FOR EVIL TO TRIUMPH IS FOR GOOD MEN TO DO NOTHING..........edmund burkeComment
http://www.copytechnet.com/forums/ra...pier-ever.html
hthInauguration to the "AI cancel-culture" fraternity 1997...
•••••• •••[§]• |N | € | o | M | Δ | t | π | ¡ | x | •[§]••• ••••••Comment
Re: Which copier was the biggest peice of crap ever?
Anybody who worked on the TOSHIBA c3511 knows it was the worst engineered copier ever! I never saw 1 with a 1,000 total prints that didn't need a $1,000 dollars in parts, MODs didn't help, Carousel developers would fling toner everywhere! Transfer Belt tore on every machine! Cleaner blade scratched the crap out of the drum, and leaked all over the laser unit. The engineers should have to fall on their Swords for that piece of junk! They looked nice though...Comment
sr-3150 i think with the booklet maker. staple head goes out of alignment. I recently had the whole of the inside removed and in bits to realign the unit, the dev units are hit and miss and it doesn't help you can't just replace the dev. ive had the pt roller stick giving patchy copies, the ITB unit shreds? the pf drive unit bends a pin giving a clicking sound - twice i've had that. the fusers are yuk.
today the black dev unit shredded a drive gear - ripped the teeth to shreds.
oh and ive had the cyan toner hopper worm screw bend and buckle to stop the toner being dropped into the dev unit.
I cant believe that they have got this so wrong when the previous range was a really good machine. I dont think ive seen many parts hit the pm cycle - bugger knows what will happen when the crappy toner hits them at my place!Attached FilesComment
Hp 9000 mfp. machine takes a million years to boot and then when you think it going to be ready some error code. ok, so you think you found the problem and same procedure again, wait, wait and wait hoping not to see the red blinking light and only to go through this again. paper jam, you have to open every jam door or cover and if you are not familar with the machine can't find the paper. stupid error codes that have no meaning that hp can't decode properly, and lct that test your nerves.THE ONLY THING FOR EVIL TO TRIUMPH IS FOR GOOD MEN TO DO NOTHING..........edmund burkeComment
emilio559
Anything that has the name FRONTIER from sharpComment
Mita 213, before all the modifications and a close 2nd place?..... Mita 213 after all the modifications.
I remember our Mita rep coming to our office and giving our sales people a hard time, saying any sales person can sell a good copier, but it takes a great salesperson to sell a Mita 213.Comment
Kevin Flynn
Anything with dispersant or a Secretary IIIComment
Hi-Tech Rick
The 3M machine that used the pink tissue paper and special white transfer paper to make a copy. First 'copier' I remember.Comment
