The Much Maligned MPC305
  • TonerMunkeh
    Professional Moron
    • 3865
    Is it me, or is the MP C305 the apocalyptically terrible chunk of crap the world has ever known?
    Hit it.
  • Coptech
    worker drone
    • 460
    Re: The Much Maligned MPC305
    Have a little faith...Ricoh can and will screw it up a little more in the next model.
    • KapeKopyTek
      • Nov 2013
      • 284
      Have you had the lever:base:rise D1172817 on the back of the tray break on you yet? If not, you will.......... Order one to have on hand.
      • Debs1964
        • Oct 2010
        • 1693
        Yes, had a couple, I carry one in my car now
        There are 10 types of people in this world, those who understand binary maths and those who don't
        • Cozmic
          If your number of posts and years didn't tell me differently, I'd say "You haven't been around the industry long, have you?"
            • 8174
            I agree not a great model, the worst issue I have seen so far is bent toner bottle contacts, had one bend on a new install, K toner not reconised, the first time I saw this I replaced the board, but now it is possible to bend the contact back with a long flat blade driver.
            Anyone else seen this issue!?
            • Akitu
              Legendary Frost Spec Tech
              • Oct 2010
              • 2595
              Scanner plate in one of my 305s acts up and slips loose a little, giving some slack to the belt that drives the scanner carriage. The scanner will go out fine, but slip on the return trip and code out.
              First attempted fixes were just re-tightening. Then moved on to loc-tite. Loc-tite did not do the trick and it has now been glued into place.
              We'll see how long the glue holds.
              • KapeKopyTek
                • Nov 2013
                • 284
                50K making a horrific grinding/crunching noise. Not good when fuser is spewing a gray gritty substance, further inspection revealed AB012077 press roller idler gear disintegrating. Also found fusing sleeve scored and p/r coming apart at the ends. After replacing fusing sleeve, p/r, and 3 gears, got a SC542-00 and found out it's cheaper to replace the whole fuser D1174025 than to mess about changing parts. "Much maligned" isn't strong enough.
                • KenB
                  Geek Extraordinaire
                  • Dec 2007
                  • 3944
                  I have a customer with at least 200 of these little "gems", and they are all running Streamline NX.
                  Did that get your sympathy?
                  It sucks to be me.
                  • Lagonda
                    • Aug 2008
                    • 1649
                    I have never, ever pulled so many parts off a copier just to change a feed clutch! Oh by the way, while your in there change the rego clutch as well as they seem to come with a generous coating of factory installed rust.
                    • Zeldaman
                      • Mar 2011
                      • 946
                      • Zeldaman
                        • Mar 2011
                        • 946
                        • amos.kaplan
                          • Feb 2015
                          • 19
                          It could be worse... Does anyone remember the Aficio 2003?
                            • 8174
                            Yeah seen a few of the fuser pressure levers break, can we just order the lever? Is it easy to replace?
                            • Bantams
                              • Jun 2012
                              • 603
                              Yes and Yes
