Humidity?
  • allan
    RTFM!!
    • 5462
    Re: Humidity?
    We are going to convert a room into a curing space, the same system used to for rapidly drying beef jerky. This customer can run thru paper quickly so it needs to take like a 150 reams of paper.
    I did think about desiccant, not sure where to get that here. The reams are all in good condition, but i have seen better sealed products.
    I wonder if thinner paper would work better.
    Whatever
    • qbert69
      • Mar 2013
      • 1152
      Re: Humidity?
      If they are going to print alot and commit a particular and appropriately sized room space for storing paper, they should buy a plug-in electric dehumidifier!...easy to use and has a settable humidistat control and when the tank gets full, the dehumidifier will automatically shut off! Something to note, if they are on a concrete slab, many times the porosity of the concrete slab can wick moisture up from the ground! What they need to do is seal the concrete AND use a dehumidifier! If they are on an outside wall, they can shelf mount the dehumidifier and plumb the drain out through the window OR, if they have a floor drain they can put a hose down into it from the dehumidifier!
      REACH FOR THE STARS!!!
      Konica Minolta Planetariums!
      • allan
        RTFM!!
        • 5462
        Re: Humidity?
        Thank for all the great advise. Yes there is a room that can be dedicated to this i have not been in there to check it out.
        Whatever
        • NeoMatrix
          Senior Tech.
          • 3514
          #19
          Re: Humidity?
          How to build a "Dehumidifier" cabinet.
          Buy a small cabinet similar to a bedside table. Drill a hole in the back an run a power lead inside the cabinet.
          Fix a 100 watt light bulb to the inside top or bottom panel. Be sure to place a cover or wire cage around the light bulb for protection. Add reems of paper inside the cabinet. Close the door. Turn on the light bulb.
          I saw few of these made years ago. You can now buy a proper dehumidifier heater to replace the light bulb.
          • Tonerbomb
            AutoMajical Resolutionist
            • Feb 2005
            • 2589
            #20
            Re: Humidity?
            I live in North Carolina. It's like a sauna here. Sounds like some crappy paper. An old army trick to remove moisture from paper is to take a metal cabinet, bore a hole in it, install a light bulb and now you have a paper incubator.
            Originally posted by Tonerbomb
            Does it hatch baby papers????????????????????????
            We call them "post it" notes in the states.
            Sorry NEO but Fix beat you to it..............................................
            Mystic Crystal Revelations
            • nmfaxman
              • 1702
              #21
              Re: Humidity?
              Google
              DESICCANT BAGS
              They are cheap and safer than a 100 watt bulb next to a flammable source.
              Paper dust can ignite when airborne with the right conditions. Check Mythbusters and igniting coffee creamer.
              When the paper starts curling again, just tape a new one in the drawer.
              • allan
                RTFM!!
                • 5462
                #22
                Re: Humidity?
                Wrinkles are usually caused by the fuser in my experience. Have you checked it for a worn out pressure roller?
                I did change one of the B601 machines LFR, these are heated aswell, I forgot that. They last well.
                Did not make any difference. I activated the dehumidifiers on the machine, but they only work with the sub switch off!! That helped a bit.
                Still going to look at the B1050. It looks extremely similar to the B1250 and I like them. The only real difference seem to be the absence of a transfer belt.
                Do these machines dump toner?
                Whatever
                  • 22997
                  #23
                  Re: Humidity?
                  AFAIK no, they haven't dumped toner for me. =^..^=
