Hello from Knoxville TN
  • Dadofmykids
    • Dec 2016
    • 27
    New to the forum. Been in the business since 1989, servicing mostly HP and Xerox with a few others sprinkled in there.
    I came to the forum because I am having trouble with a Ricoh MP 161. After replacing the upper fuser roller, I got an error SC542 because I accidentally left a screw loose on the heat lamp. I assume that's what caused the error. For good measure I replaced the lamp and thermistor.
    Now I can't get into service mode (aka SP mode) to reset the code. I've tried "clear modes" (the yellow button) then 107 and hold the clear/stop button for at least five seconds. I've tried it too many times to count. Nothing happens.
    I tested the operator panel buttons with an ohm meter. They tested good.
    Any suggestions?
    I know this is the newbie area. I will look for a more appropriate place to post my question. I am open to suggestions for best place to search and post about my problem.
    Thank you and Merry Christmas,
    Andy
  • Aneurysm
    Administrator
    • Jan 2005
    • 1072
    Dadofmykids, thanks for posting, we hope to see you back soon!
    • bob marley
      • Jan 2012
      • 1339
      Re: Hello from Knoxville TN
      Welcome
      post your question here http://www.copytechnet.com/forums/ri...tetner-lanier/
      Live for yourself and you will live in vain. Live for others, and you will live again
      • Tonerbomb
        AutoMajical Resolutionist
        • Feb 2005
        • 2586
        Welcome!!!!!!!
        Mystic Crystal Revelations
        • mx6turbo89
          • Oct 2013
          • 154
          Welcome, fellow Tennessean
            • 22994
            Welcome! =^..^=
            • zoraldinho
              teacher-guide-expert-guru
              • Mar 2008
              • 5022
