Adjust Horizontal Scan Position on Glass or Doc Feeder for Kyocera 4551?
  • CopyTech1975
    • Oct 2021
    • 17
    Having issues scanning off the glass and doc feeder, the image is about 1/8 in off the top of the page. Printing is actually fine. Is there an adjustment in service mode that will center the image or change the horizontal scan position? Found some adjustment codes but not sure which one is the right code.
    Thanks for any replies.
    • 23007
    Re: Adjust Horizontal Scan Position on Glass or Doc Feeder for Kyocera 4551?
    This is the order of adjustments of the Alphard 1 & 2.
    I know you're probably not going to take my advice, but I always do the full procedure beginning to end. You will find that if you start in the middle, you will find yourself circling around again and again, repeating the same adjustments again & again because the adjustment you just did changed something else.
    See attached:
    • CopyTech1975
      • Oct 2021
      • 17
      Thanks Again Blackcat.
