black and/or faint twisted ribbon like lines or thin bands on both sides of copies
  • samIam
    • Jul 2025
    I have a sharp AR M208n. Pulls developer mostly on front side of copier. Had to replenish about half cup. The lines on both side of copies went away after this cleanup. Ran 50 copies and the lines are back. Original ran from glass.
    Cleaned optics, charger; drum inspection: no aluminum showing--drum nearly new; Cleaned transfer roller assembly but did not replace or damage the charger roller.
    Checked fuser unit: rollers are very newish.
    Lines returned again to the same front side of copier. Suspect transfer roller and moist paper at first, but paper is decent and dry normal room environment. I did check the contact ends of the transfer roller--also the roller is even and uniform, turns easily.
    Total copy count: 110,000.
    Sam I Am
