canon ir3300
  • eddie mags
    • Aug 2025
    canon ir3300
    canon ir3300 can make copies most of the time the problem is some times when you hit the print button
    it will go right to jam in the middle of the machine. no paper found. turn off machine turn back on
    machine will work. printing to copier after end of print goes into same jam. cleaned and changed
    paper feed rollers. looking for help
    thank you
    • 23010
    Re: canon ir3300
    What jam codes and/or error codes are stored? =^..^=
    • eddie mags
      Re: canon ir3300
      just shows paper jam. no codes
      turn the copier off and back on and it works. no paper found
      thank you
      ed
        • 23010
        Re: canon ir3300
        There are jam codes. Enter service mode > display > error
        If you're having difficulty navigating service mode, you should get yourself a manual.
        Paul? Where are you? We need some more of that magic. =^..^=
        • JustManuals
          • Jan 2006
          • 9838
          Re: canon ir3300
          I have this Parts & Service manual.
          Email me if interested.
          • LaurenBrown
            Re: canon ir3300
            i have to say I currently own canon ir3025n that i am very proud off
            • eddie mags
              Re: canon ir3300
              jamming code 1081 cleaned dirty sensors in the finisher section.
              was working when i left today.
              will check again tomorrow.
