Copier Field Service Tech Rep
  • wlspar
    • Aug 2025
    Cut my teeth on the old Savin liquid 700 Series, also worked on the old e-stats Dennison and Savins. Since then I've started on the Canon One Touch worked thru up to the present day canons with a few Toshiba, Sharp, and whatever thrown in over the past 30+ yrs. Presently I'm servicing both Canons and wide format 8000 Kips and 9800 Oce' in-house
    Last edited by Guest; 11-26-2012, 07:40 PM. Reason: Thought thei info might help those that work on wide-formats
  • Aneurysm
    Administrator
    • Jan 2005
    • 1083
    Welcome to Copytechnet.com, we look forward to your participation.
    • zoraldinho
      teacher-guide-expert-guru
      • Mar 2008
      • 5015
      Re: Copier Field Service Tech Rep
      • wlspar
        Cool Man, Thanks for the welcome.
        wlspar
          • 23009
          Welcome! =^..^=
          • igi
            • 1507
            you are most welcome
            • JustManuals
              • Jan 2006
              • 9838
              Welcome aboard.
