Recommended posting format?
  • Cipher
    It's not easy being green
    • May 2006
    • 1309
    Sometimes the lack of the information being posted is problematic in it's own right.
    Would be helpful if we had a sticky post in each forum with a recommended posting format / template to follow?
    Description of the fault:
    Troubleshooting and work carried out so far:
    Attached print sample (scanned) or photograph:
    (Technicians) Attached logging data:
    (Example 5990-004 / P-Print / SIM 22-06 etc)
    Primarily we are looking for...
    Jam and error code history
    Current firmware versions
    Current part yields
    • 22996
    Re: Recommended posting format?
    It's a great idea ... and probably will never happen.
    When I was gathering similar information for a troubleshooting database, very often most of those blanks were left empty. I could use about 1/3 of the forms as is, about 1/3 with a conversation with the sender, and the last 1/3 I could make no sense of whatsoever, conversation or not. Some of these senders could not even figure out the "Sender" line.
    It makes far too much sense. =^..^=
    • NeoMatrix
      Senior Tech.
      • 3514
      aahh, Deja vu ...
      Checklist I thinks we called it...
      Hang on while I do a CTN search...
      httpp://wwww.copytechnet.com/forums/rants-raves-and-everything-else/94387-checklist-post446961.html#post446961
      checklist?
      • ZOOTECH
        Senior member of CRS
        • 3375
        aahh, Deja vu ...
        checklist?
        Good memory, Matt👍
        • Cipher
          • May 2006
          • 1309
          aahh, Deja vu ...
          checklist?
          What a good idea lol.
          Would of probably been better in feedback and suggestions though. (I never saw it, maybe the admin didn't either).
