I want to be removed from the forum!!!
  • franco@neca.it
    • Jun 2025
    I have already sent several e-mails with the request to be deleted from this forum but it is not done. Please remove me from this forum. Yours sincerely.
    Re: I want to be removed from the forum!!!
    remove yourself... it's easy to do
    • copyman
      Owner / Technician
      • Sep 2005
      • 4627
      Too bad you didn't find what you were looking for on this forum. Not sure what the big deal is about being deleted from this forum? It's not like yourt credit card is being charged every month or something.
      Very simple:
      1) Delete your profile
      2) Don't let the door hit you in the ass on the way out!
      3) Enjoy the rest of your life
        this is only the 2nd post you made....
        the 1st you created a topic ( in spanish) and the only thing you posted was:
        there is no Q nor anything of value in that post....
        this is NOT Fakebook or Twitter...
        if you have something of value to add, you would be welcome....
        but stupid posts and lack of understanding of the workings of CTN, does not make CTN the problem ... rather you are good riddance !
        Loser.
        • franco@neca.it
          Don't be angry: The fact is that I wrote several times using the link on the bottom left "Contact Us". Later I edited the post I had made trying to delete it but I couldn't. Actually at the beginning I just wanted the administrator to change my username which was entered by mistake. I have no way to do it and from what I see even to remove my profile (change it but not remove it and change the username). Excuse me if the request seems ridiculous. (It will probably also be a bad English I'm using a translator). A cordial greeting to all but I don't know how to get out of it.
            i guess you didn't read the post from copyman either, he laid out the steps...
            you should have email Aneurysm personally he is the ONLY admin here...
            • tsbservice
              Field tech
              • 7977
              The admin is only one AFAIK. He has a ton of works to do just to keep forum alive, not to mention new users doing their mistakes and pretend for a quick solution.
              • franco@neca.it
                I realize for this I don't use unpleasant ways, also because the initial error is mine. However I checked, I don't seem to have received any other e-mails from Copytechnet.com or from Aneurysm. But do you know how to do it?
                • franco@neca.it
                  Very simple:
                  2) Don't let the door hit you in the ass on the way out! ??????
                  The Forum is very valid. It was my question that had been misplaced (too many attempts to change passwords on a Xerox VersaLink B405, then I realized that the password had never been changed, but the lock prevented me from realizing it, until the printer was turned off). This is why I wanted to delete the post. Sorry again.
                  • Synthohol
                    Certified Konica Expert
                    • Mar 2016
                    • 5804
                    Using you email Addy for a user name is a huge error. Hope your spam folder can take the likely abuse.
                    Only suggestion I have is already been said to email Aneurysm.
                      • 37362
                      If it is the email notifications you do not want, it is easy. When you get the email notification for this or a reply to any thread you have posted you will see near the bottom of the post a line that says "To unsubscribe from ALL threads, please visit this page:" Click on the link below it. You will no longer get notifications until you either create or Reply to another thread.
                      Also in Settings, near the bottom left click on settings for DBTech - Post Thanks. Check all 5 check boxes.
                      You should then never get anything generated by the Forum software.
                        So IF the forum is valid..
                        Your name isn't correct
                        Frankly minor issue IMHO.
                        As far as the SITE..COPYTECH.NET I find if you give proper info... don't violate said site's rules, you can find a plethora of information, and having a CONTRIBUTOR bage will be even more beneficial to you quests.
                        (See login for contributors options)
                        • franco@neca.it
                          Ok, thanks to everyone. For now I will try to send the administrator another e-mail with the request to change my username (wrong because of me) and I will wait patiently.
                          • Trommel
                            • Oct 2019
                            • 29
                            As others already said it, the only thing you can really do is try to contact the admin "Aneurysm". You probably have to be a bit patient and keep it up until you receive the needed help.
                            Loser.
                            Furthermore I'm really surprised about the very rude replies in here. He clearly needed technical help the first time he started the thread, the problem got solved before someone could answer and he tried to edit the post afterwards. Also he accidentally put the adress as username, which I can understand can be indeed a problem, and yet is getting insulted for trying to fix this. And all of this while using a translator, he also still stays polite in the following posts.
                              • 37362
                              The replies he got were because his original post starting this thread made it sound like he did not like us.
