Disable print view?
  • zed255
    How'd ya manage that?
    • 1024
    Disable print view?
    Given the nature of the forum there are often threads where the last word in the title is 'print'. This results in the thread being displayed in a print friendly view that can't be replied to. Can this feature be turned off? Hoping Aneurysm can provide an answer.
    Re: Disable print view?
    In these cases.. I simply PM that user, inform them of the 'glitch' in the CTN software and request them to "repost" the issue again W/O the word Print as the final word in the title...
    printing - printed work instead of just "print"
    MOST users that check their PM's will comply with my PM.
    • tsbservice
      Field tech
      • 8016
      This is an old 'glitch'. Sure it's annoying but I would think if it was easy fix Aneurysm would take care long time ago.
      • ThePomqueteer
        • Sep 2016
        • 73
        I know this is an old thread, but I found a fairly easy solution to this, my apologies if this has been posted already.
        Just remove '-print' from the url.
        It worked for the thread I was looking at, seems to show the same thread without the print view.
        ie. https://www.copytechnet.com/forums/r...opy-print.html
        change it to
        https://www.copytechnet.com/forums/r...lack-copy.html
        and that seemed to fix it.
          • 23008
          Hey! Good to know. Thanks.
          It worked for me, Thanks. =^..^=
          • srvctec
            Former KM Senior Tech
            • Oct 2009
            • 827
            change it to
            I tried that with this thread and it doesn't seem to work.
            Fax received ok but will not print
            https://www.copytechnet.com/forums/k...-will-not.html
            Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.
            • tsbservice
              Field tech
              • 8016
              Tried same thread also plus one another, both didn't appear to workaround. Would check them later on PC(not phone).
              • srvctec
                • Oct 2009
                • 827
                I tried the one I posted from a PC and it didn't work, FWIW.
                • ThePomqueteer
                  • Sep 2016
                  • 73
                  Interesting, so it seems to only work on threads where the URL ends in -print but if the title itself ends in print then it won't work...
                  I'll see if I can get a work around that.
                  EDIT: can't seem to find a way to work around the print version however if you want to reply to a post on one of these threads I've discovered you can type this in
                  https://www.copytechnet.com/forums/n...1394&noquote=1
                  where the t=xxxxxx is the number at the start of the url you are trying to view (for example this thread would be 146356)
                  You can try for yourself, try clicking that link and see if it lets you reply to the link you posted above.
                  Seems like an awfully long workaround but hey at least its something.
                  • srvctec
                    • Oct 2009
                    • 827
                    Well, I'll be darned. That works and like you said, at least it's something. Still might be easier to just PM the OP and have them start a new thread. On the other hand, one could use this hack to reply to the thread ending in "print" and let them know to post another thread.
                    Now, how in the heck am I going to remember this with CRS!?
                    I guess I could just come back to this thread and copy/paste using the correct post # in the URL.
                    • tsbservice
                      Field tech
                      • 8016
                      Ha-ha should be "sticky" thread or we will quickly forget it. I was just searching for a thread that I posted month ago to add my solution, didn't go well can't find it 10 minutes.
                        • 37490
                        Then everything would become sticky and we would be in the same mess.
                        Provided we don't get hacked causing Aneurysm to have to reload everything which can sometime wipe out individual history, you can always go to "My Profile" - "My Activity" It give you the thread, the forum and the first line of what you posted. The right hand column even shows how long ago you posted it. If it is back a ways you may have to click "More Activity" at the bottom of the page a few times.
                        • tsbservice
                          Field tech
                          • 8016
                          Thanks slim for reminding me this. I know most of forum function and features but this time was stubborn as a donkey to find my thread in KM forum browsing hopefully last 20 pages.
                            • 23008
                            Am I correct in concluding that it is not a fault of the forum itself, but its a function of the web browser that I'm using?
                              • 37490
                              From what has been suggested I get the impression it is more a matter of how the forum software interprets what the web browser sends to it. I have known for a couple of years that there was a work around because I have seen replies to such posts. Until now I did not know what that work around was. It is the software that the forum runs and not the forum itself. Other forums that use the same software issue.
