Old posts ?
  • doktor
    • 214
    Old posts ?
    Hello
    How do i find old posts ?
    An example :
    https://www.copytechnet.com/forums/c...003-error.html
    Thank you
    • 37502
    The structure of the link has changed. I had to edit my Firefox Bookmark for the main forum page when I got the same result trying to access.
      When you use the new link, Google finds nothing.
      • rrrohan
        • Sep 2011
        • 1977
        the new logo made me think i was on the waybackmachine requesting a snapshot from 2001
        • tsbservice
          Field tech
          • 8018
          I think that's on purpose
          • doktor
            • 214
            That doesn't work for me.
            I have an archive of errors to which I do not have access now. I'm not satisfied !
            Old link :
            https://www.copytechnet.com/forums/c...r-advance.html
            Edited link:
            https://www.copytechnet.com/forum/te...r-advance.html
              • 37502
              Old link :
              Edited link:
              When was the post first created? If during the time from when the a backup was created and the time that the transition was completed, it no longer exists.
              • doktor
                • 214
                New link.
                https://www.copytechnet.com/forum/te...20-0001-a.html
                This one doesn't work either,at least not to me.
                • ATB
                  • Jan 2019
                  • 79
                  problem is that search within the forum seems to be broken to. for example (let's try something very specific) adriansto mentioned security bulletin 1393894 in this post. searching for 1393894 returns nothing (at least for me).
                  Good thing is that for years on old forum I haven't been able for at least 3 years to recover my password/create new accounts (I wasn't receiving emails or they weren't being sent) but since the migration to the new forum I get them and could recover my old account
                    Currently, the site is a mere shadow of its former self.
                    • jcg54
                      • Jul 2023
                      • 49
                      It seems like I can only access old posts by navigating through the forum manually? Searching just doesn't work at all. Google can find posts that I'm looking for but I just get the page doesn't exist error every time. I feel like I'm missing something that others already know about
                      • RicohBoomer
                        • May 2022
                        • 40
                        I assume the issue with dead links is an unintended consequence of the migration and will be resolved eventually.
                        But if it can't be resolved then that would be very unfortunate as A LOT of old knowledge that you honestly can't find elsewhere will be lost.
                        Not literally lost, but effectively since finding the thread manually is arduous work.
                          • 37502
                          It seems it does have to do with the migration. I have trued to search a couple of posts created since the migration and they work just fine. On the other hand if you search a post that was started before the start of the migration it will nit be found even if someone has replied to it after the migration was complete. And of course everything posted during the migration, about a 5 day period is lost, just like the administrator warned about.
                          I can see one major advantage to the problem. It will definitely reduce what I call grave robbers, those that use search and find posts from years ago that should be dead and buried.
                            • 37502
                            What I have noticed:
                            Structure for old URL https://www.copytechnet.com/forums/c...003-error.html
                            Structure for new post in email notifications https://www.copytechnet.com/node/1564442
                            Changing the old URL to https://www.copytechnet.com/node/176449 gives you a result but it is the wrong post. The old node/sequence number no longer point to the same post. All old posts received NEW numbers when the new version of the software initially processed the database. As an example https://www.copytechnet.com/node/1 brings the current home page. https://www.copytechnet.com/node/100 brings up a post from February 7, 2005 Copier model cross reference chart by Aneurysm.
                            Just for the hell of it I tried https://www.copytechnet.com/node/176400 which brought up PDF scan version in PDF scan version komica minolta from 10-19-2023. Anyone who wants can try other numbers to see what you get.
                            Doktor, the canon post you are looking for will most likely have a node number that is less than 176449. If you know the approximate date you can use the date and node number above for the KM PDF scan version as a reference as to where to start.
                            • kleankopy
                              • Feb 2016
                              • 114
                              Going and finding old post and even searching is not working. Will this ever get fixed.
                              Can't find anything.
