Recommendation for tabletop that can do 10x14 no frills necessary
  • axyun
    • Aug 2007
    • 1323
    Have customer works out of home. Cannot accommodate floor model machine.
    Must be able to sit on large table or desk yet must do 10x14. Which may mean 11x17
    machine. Customer will only be copying, so no other features are required. Also a machine
    with a decent profit margin would be desirable. Frank/ActionPhotocopy
    • 23008
    Re: Recommendation for tabletop that can do 10x14 no frills necessary
    Back in the analog days there were plenty of A3 tabletop machines. But since the transition to digital almost all segment 1 & 2 machines (tabletop) are A4. Segment 3 & 4 machine are usually A3 (with a few notable exceptions), but all are too tall to sit comfortably on any kind of a tabletop. I can't think of a single modern model that fits your criterion. =^..^=
    • KenB
      Geek Extraordinaire
      • Dec 2007
      • 3944
      Shades of the Canon GP200.
      The horror!
      • JR2ALTA
        • Feb 2010
        • 2033
        If you need 11x17 forget about a table top. But you can take an MFP and put in on a table. Just don't buy a cabinet or extra cassettes...
        This machine is dummy proof. Every consumable component removes without screws.
        • Zeldaman
          • Mar 2011
          • 946
          Hi there!
          Take a short look at the RICOH MP 305+. A-3 is possible over ADF & bypass. Looks a little like R2D2, but it works.
          Greetings...
          • axyun
            • Aug 2007
            • 1323
            Thanks guys. It doe not have to be 11x17 but needs to copy 9 1/2 x 12 1/2. In meantime I will
            look into the ricoh mp305spf.
            • Brianneoe
              • May 2015
              • 320
              Hey Frank, The Ricoh brand would work best as far as I know because of the driver command setting.
              ttyom
              • axyun
                • Aug 2007
                • 1323
                thanks brian. customer wants to copy only.
                • allan
                  RTFM!!
                  • 5462
                  brother a3 mfc-j3520
                  Well i like it.
                  Whatever
                  • axyun
                    • Aug 2007
                    • 1323
                    Thanks Allan
