Vacuum Cleaner - need suggestions
  • rrrohan
    • Sep 2011
    • 1977
    #16
    Re: Vacuum Cleaner - need suggestions
    mine just, i assume, over heats and cuts out after only about 3 mins. if you leave it for a while it might let u use it again. kinda annoying. plus it seems a lot louder than co workers vac
      • 23009
      #17
      If you were to disassemble the motor I think you'd find toner fused to all the warm parts. Eventually the filter will get holes ... the first clue is the black spot on the wall next to your vacuum. =^..^=
        • 37532
        #18
        Originally posted by catherinemarms
        Has anybody got one? Am becoming rather disabled and wonder if having one would make vacuuming easier for me can anybody recommend a specific model? A specific list of pros and cons pros would be really helpful. Thanks.
        SCS 497AJN Electronic Service Vacuum
        Available from Amazon at $279.00 and a number of other online suppliers. If you have someplace where you currently get tools, parts and tools kits, contact them to see if they carry them. SCS vacuums used 3M service vacuums.
        • rrrohan
          • Sep 2011
          • 1977
          #19
          have you got amazon link. i cant find it and in australia best i can see is $700 dollary-doos
            • 37532
            #20
            That could be because Australia has 230V 50 cycle AC whereas SCS 497AJN Electronic Service Vacuum is 120V. Here's the link though. It appears to have gone up a little over night. It's now $289.86
            SCS 497AJN Electronic Service Vacuum, 120 VAC (Replaces 497AJM): Amazon.com: Industrial & Scientific
            One thing, it does not show any attachments other than the hose. Try searching copier service vacuum and look at any Atrix vacuums that show up.
            • tsbservice
              Field tech
              • 8020
              #21
              Wonder how those spammers find so old threads and push them up.
              • Synthohol
                Certified Konica Expert
                • 5847
                #22
                i lit 13 candles and chanted the words in that post and now my sister-in-law is no longer paralyzed, the dog no longer pees on the rug and my hair is growing back.
                Thanks WEas2!!
                • tsbservice
                  Field tech
                  • 8020
                  #23
                  Thanks WEas2!!
                  You Sir have very fine sense of humour. It's almost to the point when I'm jealous 😂
                  I don't know which Synth I like more - engineer or sarcastic wise man
                    • 37532
                    #24
                    You Sir have very fine sense of humour. It's almost to the point when I'm jealous ��
                    Just remember, thew definition of Synthohol is synthetic alcohol. How Synthehol Works | HowStuffWorks
                    • subaro
                      • Oct 2010
                      • 1274
                      #25
                      Those 3M Vacuum are too darn heavy. Most of the techs I Know only use them when absolutely necessary. The yellow toner cloth from katun does a good job, for most jobs. I hated carrying those together with the tool bag was a drag, but they worked good and is indeed noisy. Some customers did not like their noise level at all.
                      • tsbservice
                        Field tech
                        • 8020
                        #26
                        Heavy or not vacuum cleaner is absolute must. I prefer it to be in my trunk as a backup, I don't have to carry it to every machine I visit so not a big deal
                        • subaro
                          • Oct 2010
                          • 1274
                          #27
                          No objection to your reply as I agree with that. I was just ranting about the dislike I have to being loaded with one on a call. However, now I know how effective those yellow coths are, I can do everything a vacuum can do. use 10 of them on a call, put them in a bag and vacuum them at home and resuse them. If I ever work in the field again, this is how I would work around the vacuum. Many times, in places you could not use the vac, as to the environment, especially office.
                            • 37532
                            #28
                            Having to carry a vacuum is nothing. Years ago I used to on Vydec word processors. When I went on a call on one of them, in addition to mt tool kit I had take along an oscilloscope and 2 components carry cases, one 18x24x15 for large components and one for 18x324x6 for small boards. I had to use a luggage cart to carry everything in one trip.
                            • Vincent128
                              • Sep 2015
                              • 349
                              #29
                              The size and weight of the 3m is axactually why I got my Craftsman sit and tote tool box...The vac fits perfectly in the large compartment and tons of room left for chemicals and tools. You can use it as a seat, pile on tons of Pm kits boxes and just wheel it away... Sadly, it's been discontinued, and I have not found any replacement. The one I am using now is nearly worn out completely.
                                • 37532
                                #30
                                Originally posted by wellos
                                Guys, I read this topic and realized that I want to share useful information about vacuum cleaners with you. Surely you have thought about how to quickly remove the leaves from the lawn? Check out this blog wooftowndoggydaycare.com for comparison information on leaf shredders. This is a fairly quick and convenient solution to keep the lawn always clean and attractive. I hope this will be useful to you.
                                Another stupid spammer.
