Copier Hoist
  • arnh79
    • 469
    Copier Hoist
    Does anyone have any experience with this product: Copier Lifting Equipment – Make Lifting Simpler and Safer or something similar? We're looking for something that will allow us to install/remove copiers on stands/pedestals in our warehouse.
    Why does every customer think they're the first one to ever say: "you've been here so much we should get you an office, ha, ha, ha"?
  • PrintWhisperer
    • Feb 2018
    • 474
    "Being ignorant is not so much a shame, as being unwilling to learn" - Benjamin Franklin
    • JLSam
      • Jun 2015
      • 605
      Re: Copier Hoist
      Deleted.
      • srvctec
        Former KM Senior Tech
        • Oct 2009
        • 827
        Re: Copier Hoist
        That's pretty cool!
        Originally posted by PrintWhisperer
        Imagine those four straps with hooks….attached to forklift forks.
        This is exactly what I've been thinking about doing for a few years now since none of us are getting any younger at our office. My design would basically be a square frame that has forklift channels underneath to prevent any movement on the forks. Then just attach adjustable straps to that to hook to the copier and lift it up. We'd probably use Rope Ratchets (which is already what we use for copier tie-downs for over 20 years) and just hook over the top of the frame into holes drilled at different spacings to accommodate the hooks.
        I could just weld up the frame myself and it wouldn't even cost more than $100, I would think.
        Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.
          • 37628
          Re: Copier Hoist
          As shown in the video it is lifting a Ricoh with SPDF. Lift points on those are different height on each side. If you want to make your own, the hooks need to be the correct width for the hand lift points. Too wide and they won't fit. Too narrow and they could damage the side covers. Some 2' wide load tie downs come with the proper hooks already attached. https://cdn.shopify.com/s/files/1/02...g?v=1616791949. Each strap need to be independently adjustable so you can put the hook in place and then take up the slack. Whatever attaches the straps to the frame needs to meet a couple of criteria:
          1. Must allow for easy adjustment to take out slack
          2. Must be able to hold the weight of the load
          3. Must not be easy to accidentally release by bumping into them
          The old seat belt adjustment buckles pictured might not meet #3.
            • 23010
            Re: Copier Hoist
            One of our managers has a bad hip, and the ingenuity to invent this exact thing. It's some heavy duty truck straps that attach to the forklift forks. 100% successful, and cost him a few nuts washers & bolts to attach the hooks. =^..^=
            • toddanderson
              • Dec 2005
              • 238
              Re: Copier Hoist
              Do the same thing with a harbor freight winch from the ceiling, we use similar hooks
              • srvctec
                • Oct 2009
                • 827
                Re: Copier Hoist
                Originally posted by srvctec
                That's pretty cool!
                  • 23010
                  Re: Copier Hoist
                  Nice MacGuyver! Ingenious. =^..^=
                  • srvctec
                    • Oct 2009
                    • 827
                    Re: Copier Hoist
                    Thanks!
                    Believe it or not, back in the mid to late 80's when I worked at K-Mart while going to electronics school, that's what everybody called me, MacGuyver. Of course, that's when the show was on TV.
                      • 37628
                      Re: Copier Hoist
                      Looks like it should also work for setting a new machine onto a paper bank or copier stand.
                      • srvctec
                        • Oct 2009
                        • 827
                        Re: Copier Hoist
                        Yeah, it's going to be handy for lots of stuff.
