no more crawling on floor looking for wall outlet
  • 33technp
    • Apr 2022
    • 4
    No more crawling on the floor looking for a wall outlet to use my vacuum. With my new cord I plug the copier AC cord into one end and vacuum into the other end.IMG_3809.jpg
  • rthonpm
    • Aug 2007
    • 2853
    Re: no more crawling on floor looking for wall outlet
    And for no extra cost it also works as a massive space heater/fireplace in the winter.
    • 33technp
      • Apr 2022
      • 4
      pennsytucky Im sorry I dont understand your reply?
      • KenB
        Geek Extraordinaire
        • Dec 2007
        • 3944
          • 23007
          You can buy C13 & C14 connectors and make your own cord ... or buy a cord C13 to C14.
          It didn't look too dangerous to me, just awkward explaining all the black tape when the customer asks.
          Funny story:
          For about a month I noticed that the vacuum kept cutting out ... unless I wiggled the cord at the receptacle end. I didn't think any more about it until one day I was vacuuming away when the vacuum motor began slowing down and I noticed a stream of gray smoke editing a small hole in the 15P connector for my vacuum. Then it was a tongue of flame about an inch long. Apparently the hot had shorted to one of the other terminals, and was creating a new conduction path through the connector. I always have a copier cord or two in the trunk, and I used one of those for a while, until I could get another 15P. It's a little too exciting when my tools start on fire, especially while I'm using them. =^..^=
          • anothertech
            • 1768
            If you unplug the machine while vacuuming, is it still safe to vacuum? The machine is no longer grounded, so I thought that was a bad idea due to static build up.
              • 23007
              Good point. The chassis should always be grounded to avoid arcing, possibly damaging boards.
              My first vacuum did not have a ground contact through the hose, so when vacuuming developer you'd get: ... snap snap snap ....snap when the agitated developer discharged. You could minimize the arcing by keeping a thumb on the developing roller, but you still felt the discharge through your thumb. To prevent the arcing entirely I wrapped the nose of the vacuum wand in brass, and soldered a ground wire to it. Then I put a banana tip chassis mount connector to plug the ground cable into.
              No more arcing. Later on, 3M started making the hoses conductive, so I didn't have to ground it any more. =^..^=
