Borderless Printer
  • OlliK1969
    • Nov 2016
    • 311
    Borderless Printer
    Hello
    We are looking for a color laser printer for a customer that prints absolutely borderless. Question: Is there such a thing, from which company and does anyone have experience with it. Any idea or suggestion is welcome.
    Thanks for the help
  • allan
    RTFM!!
    • 5462
    Re: Borderless Printer
    Konica Minolta AccurioPress C14000 uses a cutter option to make full bleed prints.
    Whatever
      • 23009
      That's what cutters were made for. Even if it was possible to print without voids, all the prints from laser based devices would wrap into the fuser.
      Print onto larger paper an cut off the margins. =^..^=
      • kingarthur
        • 1366
        on Konica Minolta devices, they have the ability to print on SRA3, which is larger than A3, it's designed so that it can be trimmed to A3, and you have "borderless printing"
        • Gift
          • Mar 2011
          • 2459
          Originally posted by terramobil
          On Ricoh machines using the PCL Drivers you can select "Edge to Edge" printing. This will not work at the leading edge, but the other three edges are really borderless. I hope this will help.
          Not shure if that's a good idea to use this feature too often or even all the time. Can't tell from experience though.
          • Elmo
            • Feb 2010
            • 541
            Ricoh and Sharp also has the ability to print on SRA3
            I Used To Live To Fix Things Now i Fix Things To Live
