Greaseable Clutch Grease
    • 23008
    Does anybody have a current number for Canon's Teflon Clutch Grease?
    The number I have is no longer valid: DU0-0079-000
    I have substitutes that aren't quite as good, and I'll use them. IB-23 and Mita Ball Bearing Grease.
    But I'd prefer the good stuff. =^..^=
  • Tonerbomb
    AutoMajical Resolutionist
    • Feb 2005
    • 2589
    Re: Greaseable Clutch Grease
    can't help with the Cannon grease, But the grease I use almost exclusively is Superlube. It has great thermal characteristics,and contains PTFE and readily available at places like Harbor freight. They also make it as an oil. These and a conductive grease are the only lube in my bag...
    Mystic Crystal Revelations
      • 23008
      Thanks Tonerbomb. I'm somewhat of a collector of lubricants. I've got 6 different greases, 3 different oils, and 7 different solvents/cleaners. Each has it's own uses.
      Mostly I use:
      my own formula of glass cleaner: on glass or as a final rinse
      Contractors De-Sol-Vit (orange oil cleaner): on rubber or plastic
      Zep fast505: great on plastic covers, especially old ink
      Triflow light oil: lubricant
      Why my own formula of glass cleaner? I've had a bad experience with ammonia and cannot tolerate it at all.
      My recipe is two gallons of the low temperature windshield washer solvent, two quarts of Vinegar Windex (no longer sold, I bought up the last three cases), one pint cleaning vinegar. Total three gallons lasts for 3 years (~$7)
      • Tonerbomb
        • Feb 2005
        • 2589
        Yeah BC I've got a collection of lubricants in the garage, Mostly from vehicles and electronics. I can go to the garage and find the bottle of turbin oil in 10 seconds. Used for electric motor bearings. In the car I carry Zep glass cleaner and Zep GP cleaner for covers ect. and I do have a small bottle of DeInk, a product that is an ink solvent. However if you clean covers with it, you have to rinse the cover immediately or the plastic will melt...
