24" Wide format scanner
  • tmaged
    Owner/Service Manager
    • Oct 2008
    • 1887
    I have a library looking for a scanner to save old newspapers that are 11 X 23.
    I see HP has the Designjet T830 that has a scanner. I'm not sure how the scanners are on these and if
    they would work for that type of application ? I would rather recommend something more expensive that
    wouldn't be a problem for them. Anyone have any input ?
    Thanks !
    Hope that helps !
    -Tony
    www.dtios.com
    Become a fan on Facebook
    • 37520
    Re: 24" Wide format scanner
    Any wide document printers that has for copying construction documents scanners on will work. I know both Ricoh and Epson make them.
      • 23009
      If they are old crumbly newspaper, the HP T830 will wad them up and spit out the pieces. You almost need a transparent sleeve to slip the newpaper sheet into. Or a large flatbed scanner.
      One of my customers was scanning 100yr old blueprint originals. They ended up adhering them to a backing page with spray adhesive, or the original would come out the other side of the scanner in crumbled bits. Perhaps that's the solution. =^..^=
      • tmaged
        • Oct 2008
        • 1887
        Thanks for the input. I called Scantastik and talked to them. She said a flatbed would probably be the best option.
        She also mentioned about putting them in a large sheet protector if you were going to run them through some type of feeder.
        I appreciate it !
        Hope that helps !
        -Tony
        www.dtios.com
        • mardosoo
          • Oct 2023
          • 2
          For digitizing 11 X 23-inch old newspapers, it's advisable to choose a specialized book and document scanner designed for preserving delicate materials, such as the Epson Expression or Fujitsu ScanSnap series. These scanners offer high-quality scanning and gentle handling suitable for archival purposes, ensuring the preservation of historical documents. The HP Designjet T830, primarily a large-format printer with scanning capabilities, may not be the optimal choice for this specific application.
            • 37520
            Originally posted by closme
            The best drivers license scanner for Android, you'll want software that provides reliable scanning and data extraction. Look for features like accurate OCR (Optical Character Recognition) technology, support for various license formats, and compatibility with your Android device. It's essential to consider your specific business needs and check user reviews to ensure the chosen software meets your requirements. A good driver's license scanner should streamline your processes and enhance efficiency.
            We've got us some more spam bots.
