Ricoh MPc3502 scan to email
  • qbert69
    • Mar 2013
    • 1152
    #31
    Re: Ricoh MPc3502 scan to email
    Originally posted by Reed
    If the machine has problems authenticating and you know you have the correct email and password try a different port. I haven't set up a Ricoh but on the newer Kyocera I have used port 587 for gmail.
    Hey!...At least Kyocera gives you an SMTP error code!...e.g - error - 0x1105 - note: SMTP protocol is not enabled. What to check - 1. Confirm device's SMTP protocols.
    All of this can be tested, checked and corrected from within Kyocera's Web Image Monitor!
    Last time I checked, you had to be physically standing in front of a Ricoh to test SMTP connection or scan to SMB connection! RETARDED!
    REACH FOR THE STARS!!!
    Konica Minolta Planetariums!
      • 37502
      #32
      So does Ricoh. User Tools - System Settings - Interface - Print List. Last page of the print out will show what the most recent SMTP, SMB and FTP error codes were. They are industry standard error codes.
